Browsing this Thread:
3 Anonymous Users
88BlackZ51 | Issue bolting up Holley TB to Miniram! | ||
Another issue:
As you can see in the pictures, I am having another issue in regards to bolting on the 58MM Holley TB to the TPIS Miniram. I took off the stock lower TB piece, and bolted it on the Holley unit(lower unit has the sensors/pipe). The issue now is that the pipe is rubbing up against the waterneck and I can't bolt up the TB. For the record this is the TPIS waterneck, and not an aftermarket one. Anyone else experience this issue? Any ideas what to do? [IMG]http://i195.photobucket.com/albums/z275/88blackz-51/421swap019.jpg[/IMG] [IMG]http://i195.photobucket.com/albums/z275/88blackz-51/421swap020.jpg[/IMG] |
Posted on: 2009/8/26 0:56
88BlackZ51 | Re: Issue bolting up Holley TB to Miniram! | ||
I am a dumbass. I have to cut it off. I got all excited for nothing!
Posted on: 2009/8/26 1:09
BrianCunningham | Re: Issue bolting up Holley TB to Miniram! | ||
ready
fire aim! ![]() j/k glad you found the problem ![]() |
Posted on: 2009/8/26 1:13
it wont be the last issue...
Posted on: 2009/8/26 1:23
Matatk | Re: Issue bolting up Holley TB to Miniram! | ||
Are you referring to the coolant passage for cold starts (ie, throttle body bypass nipple)? If so, glad you found your issue. Matthew PS, I deleted the other duplicate thread. |
Posted on: 2009/8/26 2:12
