167 user(s) are online (91 user(s) are browsing Forums)
Print in friendly format Send this term to a friend  Grand Sport
RPO Z16.
A one year special. 1000 were made to honor both the end of the C4 and the original racers, called Grand Sports, from 1963.
All were...
400hp427vette What octane fuels are you using?
Long Island, NY
373 Posts
I am using Cam2 110 because its leaded. But is the 110 really needed. What are you guys using?
Posted on: 2009/3/12 1:53
Durango_Boy Re: What octane fuels are you using?
I use 87 in my Vette right now but the new engine will require 91 or maybe even 93.
Posted on: 2009/3/12 1:56
psycovette Re: What octane fuels are you using?
Spokane, Wa
57 Posts
For some F*(&)ed reason my baby will only un on premium ( not that I care ) but for a low HP motor it should befine on regular. I tried it once and it pinged like no tomorrow. Oh well whats 20 more cents agallon
Posted on: 2009/3/12 4:42
Spend money I don't have, on things I don't need, to impress people I don't know.
Anyone can restore em...it's takes a real man to cut one up
Curtis1974 Re: What octane fuels are you using?
Bolingbrook, IL
1070 Posts
Nothing but good old fashion 93 octane!
It makes pretty decent gas mileage until I put my foot through the floor, and with the DB built motor that's pretty hard not to do..........
Posted on: 2009/3/12 8:56
Purchase date: 11/23/2003
Like when you're racing motorcycles? LOL.
Posted on: 2009/3/12 9:49
Trae1976 Re: What octane fuels are you using?
Johnson City, TN
832 Posts
:me2:
Posted on: 2009/3/12 10:36
Bolingbrook, IL
1070 Posts
Hey now, I was baited into that! LOL...........However, it was fun to see Danny's 2000cc motorcycle fade away in the rear view!
Posted on: 2009/3/12 12:41
tjpreul Re: What octane fuels are you using?
I use 93. I've put in 87 before it ran fine, but it seems smoother with the 93.
Posted on: 2009/3/12 13:29
bogus Re: What octane fuels are you using?
20861 Posts
welp... lets see... I use 91. That's the best that I can get here in CA. And it's fine.
As for the your 427... I don't think you need 110!! Even with lead, you don't need that much. On the flip side, if all you do is drive it 1500 miles a year (collector car and all) then by all means, put that in it. It won't hurt and some of the options are more aimed at regular usage. I would run 93 in it with a lead additive. The 400hp version of the 427 wasn't high compression. It should deal ok with 93. It wasn't until you got to the 435hp version (L71) and the L88 that 103 was required.
psycovette - I would think you're engine is seriously carboned up. Have you tried seafoam? It might just clean up the problem. There is no reason for that engine to ping on 87. Check your timing, too.
As an aside, what does octane do? The higher the number, essentially, the less volatile it is. It's that simple. The less volatile, the less prone to uncontrolled combustion. The flame front can be more intense and longer burning with higher octane. 87 will pop and be gone... 93 will pop and linger. Either way, it's a blink of a blink of a blink of a blink of an eye.
Putting higher octane will only give you the power the engine was designed to give, as long as the engine was designed to work with it.
Posted on: 2009/3/12 14:53
BrianCunningham Re: What octane fuels are you using?
Depends on the compression.
If it's original, or built to original specs, then yes it does.
Posted on: 2009/3/12 14:57
I agree, something's off if you're pinging. I seem to remember the engine but if you could give us some details that would help. Maybe start a thread about that in tech and we'll pick it apart and figure out the problem and hopefully a solution.
Posted on: 2009/3/12 21:40
BillH Re: What octane fuels are you using?
I pretty much agree with Andy. If the C/Rs are the same in the C3 as a C2, it's interesting that the C/R isn't that much greater, it's 10.25 to 1 for the 400 and 11.0 for the 435, also interesting to note is that the 300 horse SBC had 10.25 while the 350 horse had 11.0. ( the L88 had 12.0)
Nobody I know runs 110 in a 350 horse. I think it would be fine with the 93 and lead add if there's minimal carbon buildup and the timing's not jacked.
Second on the seafoam.
BTW, I run 89 in the LT1 all the time and at high altitude with zero ping.
Posted on: 2009/3/12 23:44
NC Kid Re: What octane fuels are you using?
North Carolina
1671 Posts
93...I have a gas card that gives me a discount so it's the same price as regular at most places. It is doing no harm so it really doesn't matter either way. It gives me no advantage with the little horsepower my car makes. Oh well...
Posted on: 2009/3/13 1:03
400hp427vette Re: What octane fuels are you using?
Long Island, NY
373 Posts
Another reason I forgot to mention is 87-93 octane pump gas has 10 percent ethanol. I know ethanol burns hotter and I just wouldn't feel good if I put it into the tank. I guess I am paying extra for piece of mind.
Posted on: 2009/3/13 2:20
Your peace of mind is what's most important.
We usually have the ethanol mix here too, but I'm running it in a 10.2 LT1.
What are you paying for 110? Here, at the racetracks, leaded is $7.50/gal or higher.
We also can get 100 leaded here.
Many years ago, I ran my '63, 360 HP all the time on pump gas (leaded hi test) which was maybe 93 - 95 octane. I ran it that way 4 years as a daily driver and pulled the motor apart w/ no evidence of preignition. 11.25 C/R.
Posted on: 2009/3/13 13:47
LTX cars are reverse cooled so we can get away with a higher compression.
We also have a knock sensor that backs the timing off.
Posted on: 2009/3/13 15:20
Yea but the compression's not really that high.
The knock sensors and O2 sensors let me run the 89 even at high altitude.
Posted on: 2009/3/13 19:20
gbags Re: What octane fuels are you using?
Houma,La.
8 Posts
I use 87 for now seems to run fine
Posted on: 2009/3/16 0:56
xccter Re: What octane fuels are you using?
Downtown Annapolis, MD
461 Posts
I use 87 octane in the '71 (stock L48)
and 93 in the '88 (stock L98).
Posted on: 2009/3/16 1:02
ยด71 350/270 L48 Coupe
NCRS #48337
Long Island, NY
373 Posts
I am paying 8.50 a gallon but I put about 300 miles on the car last year. To top it off it got about 17 miles per gallon
Posted on: 2009/3/16 3:11
Ah hell, for $150 a year, you can run it.
Must be hard to only run 300 mi. with a car like that!
Posted on: 2009/3/16 14:19
Long Island, NY
373 Posts
It is i am hoping to break the 1000 mile mark with it this year.
Posted on: 2009/3/17 2:26
Theiskell Re: What octane fuels are you using?
Liberty, MO
22 Posts
I run 93 in mine,(10 to 1 CR) but one of my buddies runs the 110 and just filled up for 4.00 a gallon. He was so excited he took a 55-gallon drum back to fill up for later. Last year he was paying close to 10.00 a gallon.
Posted on: 2009/3/17 13:45
