270 user(s) are online (100 user(s) are browsing Forums)
BrianCunningham Opti alternative?
For now, I'm sticking with the opti, just bought an MSD unit.
But for those looking for an alternative.
Getting the dash to work might be a real PITA though
http://www.eficonnection.com/eficonnection/coil_per_cylinder.aspx
Posted on: 2009/1/5 2:11
Matatk Re: Opti alternative?
22815 Posts
Posted on: 2009/1/5 2:38
Aboatguy Re: Opti alternative?
My Avatar was redistributed!
498 Posts
Interesting link..... but not as interesting as your avitar....
Too bad keeping the factory dash is a sticking point with opti-replacement
Posted on: 2009/1/5 2:40
BrianCunningham Re: Opti alternative?
How are people doing it with a full LSX swap?
Posted on: 2009/1/5 2:44
pianoguy Re: Opti alternative?
Too bad that's not a bit more plug-and-play - having LS engine management would be outstanding.
Posted on: 2009/1/5 2:55
bogus Re: Opti alternative?
20861 Posts
They use the LSx PCM.
I have the LTCC and it has been there for over 6 years. It has been VERY durable.
The LTCC uses the existing opti as the crank sensor and fuel timing. The upside is that you don't have to get a new PCM or all the mechanical upgrades.
The only thing to address is the location of the LTCC box. It is NOT happy with heat... so it must stay cool. The best place to put it is in the left headlight bucket.
I rewrote the installation manual for Bob a number of years back. He did the LTCC for the Camaro and b-bodies, hense, he was unaware of the special needs of the 1992 Corvette.
I HIGHLY recommend the LTCC.
Posted on: 2009/1/5 3:44
are they still selling the LTCC?
Been posts "over there" about them not.
Besides, you still need the opti for the timing signal
With this you don't.
But how do they interface it with the dash?
Posted on: 2009/1/5 3:49
20861 Posts
The dash interface is the big issue. I don't know how they get around that.
The earlier dash is easy; the atari dash still uses conventional signals. The ABS is a purely stand-alone system, as is the climate control.
The later style, with the CCM is the problem. The CCM needs engine data (vehicle speed from the VSS is #1). Without that, you lose ABS/ASR...
I still haven't figured out the way to fix this... unless the CCM can be tapped into the VSS to satisfy its need.
Otherwise, the CCM handles VATS and that's about it.
The page still populates for the LTCC stuff... donno if that means anything, tho.
Posted on: 2009/1/5 4:04
Schrade Re: Opti alternative?
What does the 'Test Vehicle' have now? Does the 'Coil per cylinder' work on every one of these setups?
This S10 was originally a 1982 GMC Sonoma that went through the following changes:
* 1986 S10 4x4 Frame
* 1986 S10 Dash
* 1986 2.8L V6 Engine
* 1993 S10 Grille
* Choo Choo Customs Fiberglass "Wildside" Bed
* Choo Choo Customs Fiberglass Front Fascia
* 1987 5.7L Tuned Port Injection Engine
* 700R4 Transmission
* 1993 Typhoon Drivetrain
* 1996 Z-28 Rear Disc Brakes
* 1995 S10 4x4 Frame
* 1993 S10 Digital Instrument Cluster
* 5.7L Engine, LT1 Intake Manifold, LT4 HOT Cam
* 4L60E Transmission
* 5.7L Ram Jet 350 Intake Manifold, Coil per Cylinder, Electronic Throttle
This page was last updated 9/10/08.
Posted on: 2009/1/5 10:31
anesthes Re: Opti alternative?
Boston, MA
That part is easy. 4k PPM signal. Most of the fbody guys use a dakota digital converter.
http://members.cisdi.com/~anesthes/dash/
4k PPM from the dakota box into the CCM/BCM.
In theory, the CCM will master the aldl comm too. If the ECM is 'missing' it might trip a sys light, in which case I'd pull the bulb.
Everything else on the cluster is a "normal input".. The odometer is the only issue with the late style dashes, and the reason I abandoned my dash swap. S10wildside - a thirdgen.org member owns EFI connection (Brian's first link).. These guys have been working on some pretty neat stuff. I'd switch to an LS1 ECM if it didn't have a 750cfm read limit.
-- Joe
Posted on: 2009/1/6 3:12
750cfm???
Posted on: 2009/1/6 3:42
Boston, MA
750cfm???
Yes, if you convert it out it won't read higher than 750CFM or so CFM. If your moving more air than that (blower) you'll end up using RPM vs TPS / PE to add extra fuel based on an RPM guess.
I'm not 10000% sure all code masks have the same limitation, but considering the voltage / gram output is the same on all the GM MAF's for vortec/lsx I don't see how you would get it to read higher unless you modified the code and bought a MAF with an adjustable output.
-- Joe
Posted on: 2009/1/6 12:37
Check this out,
just the remote WP would fix a lot of problems.
[QUOTE]STL94LT1;
I caught this on the camaroz28 forum, looks very interesting. He's also running a remote electric water pump.
[IMG]http://i116.photobucket.com/albums/o4/roadtrip120/Jesselbeltdriveinstall001.jpg[/IMG][/QUOTE]
Posted on: 2009/2/11 22:28
anesthes wrote: I'd switch to an LS1 ECM if it didn't have a 750cfm read limit.
-- Joe
Is the CFM measurement scale linear, or logarithmic?
If linear, then you could re-assign the range of values from 0CFM=0CFM, all the way to 750CFM=1100CFM (if your blower max'es at 1100CFM, for example).
If the scale is logarithmic in the LS1 ECM, your value curve would have to be totally synchronous in the 'lookup' tables...
Posted on: 2009/2/12 4:05
VetteUSA Re: Opti alternative?
103 Posts
Another alternative is to just buy a ZR1. Resized Image
Posted on: 2009/2/12 4:23
I can do w/o the extra 300lbs :o
Though that raises an interesting question of how hard would it be to put the LT5 coil packs on an LT1.
For the record, except for a cap & rotor @ 110k, mine's been running fine.
I'm just putting alternatives out there.
I've already bought an MSD opti.
Posted on: 2009/2/12 5:19
103 Posts
if/when (knock on wood) my opti goes out, i've wondered which route i'd go. I could go with the coil packs, (for some reason Delteq is the brand I always remember when thinking of coil packs for the LT1), or i'd buy an MSD opti, and most likely I would go with the MSD. The optis are fairly robust anyway, the only time they usually go bad is when there's a water pump failure. I wonder if the actual installation time for the coil packs takes about the same time as just swapping in a new opti. Let's just hope my current opti never goes bad and that I'll never have to make the decision.
Posted on: 2009/2/12 5:35
20861 Posts
The solution for the 750cfm limit might just be the ZR1 code mask... just a though.
Posted on: 2009/2/12 7:08
