248 user(s) are online (112 user(s) are browsing Forums)
9T4 '94 CCMCode Pull
Northern Cal
11 Posts
I read the code pull info pdf and it says it applies to 92/93 only. If ODBII didn't come out until '96, and my '94 has ODBI, what is the difference between pulling the codes for the 92/93 and the 94? Were the pin-outs changed on the '94 CCM connector or is the whole procedure different?
The car is a stock '94 coupe. The problem i have is the digital read out for the oil temp always reads zero but the gauge seems to be working.
Posted on: 2008/11/21 17:00
"You can be on the right track and still get hit by a train!"
Stock '94 LT1, Polo Green and Auto Tranny
Schrade Re: '94 CCMCode Pull
It can be done on a '94, with a paper clip. Can't remember the DIC button-press sequence, but it's posted here somewhere...
Found it:
http://www.corvette-guru.com/modules/ ... t_id=49963#forumpost49963
Posted on: 2008/11/21 17:13
9T4 Re: '94 CCMCode Pull
Northern Cal
11 Posts
Cool! Thank you
Posted on: 2008/11/21 17:26
9T4 wrote:
Cool! Thank you
You're welcome.
Forgot to tell ya' tho'; ya' gotta' post pics, codes, and photo doc the repairs!
Posted on: 2008/11/21 19:15
Northern Cal
11 Posts
Ahh, I knew there was a 'cost' for the 'free' advise. I've been trying to get a digital cam on ebay but keep getting outbid. Maybe i should hold off on any repairs until i get a camera. Not!
Posted on: 2008/11/21 23:11
Matatk Re: '94 CCMCode Pull
22815 Posts
I bought a cheap sanyo digital camera at walmart for $89 last year. It's 7 mp and turned out to be an awesome camera! Just some food for thought.
Posted on: 2008/11/21 23:50
Northern Cal
11 Posts
I thought i should follow up on my original post in this thread.
From researching on the 'net i have learned that a 16 pin ALDL connector was used in '94, instead of the 12 pin used in earlier years, in preparation for the ODBII system. On the 16 pin connector the paper clip trick works if you short pins 4 and 12 so a code pull can be done. I think. Still need to try it though.
Most of the info i learned came from this site:
[url=http://www.aldlcable.com/sc/toplevel.asp?cat=0[/url]
Good pics and schematics if you want to build your own cables to use a computer and some of the software that's out there.
Now, here is where i hang my head and shuffle my foot.
The 'failure' in the oil temp readout? I was looking at the very bottom of the screen and saw
OIL 0F (where is that degree sign)
Doh! Silly me
Posted on: 2008/11/24 4:22
Build your own interface cables? I'm there! Which link???
From here:
http://www.corvettebuyers.com/c4vettes/codes.htm
The $89 cost of a digital camera you will get back whenever you sell your car, because it has photo-doc'ed dated repairs, which increase the marketability of the car.
Details, details, details...
D'oh
Schematic is for RS-232!!! Need USB!!!!!!!!
Posted on: 2008/11/24 4:40
Northern Cal
11 Posts
Photo doc repairs? That's interesting. I thought the pics were only for forum use. Good point Blade.
BTW i ordered a cam from WallyWorld. The crazies on ebay were paying more than they could buy for on the net somewhere other than ebay.
Posted on: 2008/11/24 4:56
Northern Cal
11 Posts
From here:
D'oh
Schematic is for RS-233!!! Need USB!!!!!!!!
RS232 too slow for ya? Picky, picky.
I'll search for it. Don't like my chances, but...
Posted on: 2008/11/24 5:15
22815 Posts
I built my own serial port cable a few weeks ago. Cost about $9. If your computer only has USB I guess it's a little harder. Good luck.
Posted on: 2008/11/24 16:23
