Ramrod | C-6 Wheels | ||
Will C-6 wheels fit on a 96 C-4 without too much hassle
Posted on: 2008/8/4 4:56
1996 LT-1 DynaSpark Opti, Tapered Rear Wheel Bearings, SS Brake Lines, Speed Bleeders, MC Bias Spring, Hawk HPS Pads, MSD Wires,NGK Iridium, lowered, etc. |
bogus | Re: C-6 Wheels | ||
I think the offsets are different.
Posted on: 2008/8/4 5:55
CentralCoaster | Re: C-6 Wheels | ||
If you know the offsets and widths of the C6 wheels your using I can answer that question.
Posted on: 2008/8/4 6:19
Ramrod | Re: C-6 Wheels | ||
Offset being, the area where the wheel meets the hub and the area where the tire meet the wheel, offet is this distance?
Posted on: 2008/8/5 4:07
No. It's from the imaginary centerline of the wheel to the mounting surface on the hub. Usually easy to find. Both width and offset effect fitment.
I googled C6 wheel offset that and found this: Base model front: 18x8.5 offset: +56 mm Base model rear: 19x10 offset: +79 mm The fronts will fit the same as your stock fronts. The rears will tuck in 3/4" more than your stock rears and will need an adapter to look right. |
Posted on: 2008/8/5 5:31
runner140 | Re: C-6 Wheels | ||
On my least favorite place to shop, ebay, they sell spacer/adapters 3/4" for $59.00 plus $5.00 for shipping for two.
Find a seller with 100% positive feedback. |
Posted on: 2008/8/5 11:51
96, white and a ton of miles. Somewhat stock. |
If you get reproduction/chinese wheels, you sometimes can't use adapters that are thinner than the 1-1/8" stock wheel studs.
If you get OEM c6 wheels, you're fine. |
Posted on: 2008/8/5 20:17
Fronts are 8.5 rears 10, thanks for all the information, so quick!
Posted on: 2008/8/6 5:18
After thinking about it for a bit, this is the only place where you can get the correct info so fast, thanks again.
Posted on: 2008/8/6 5:22
JonnyAngle | Re: C-6 Wheels | ||
go to lakeshorewheelandtire.com And click the "corvette specials."
Posted on: 2008/8/6 14:03
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. ![]() |
There's lots of misinformation on wheel fitment out there, so beware of what you hear elsewhere.
Posted on: 2008/8/6 17:31
