139 user(s) are online (89 user(s) are browsing Forums)
Also known as the DIC.
c4-zo7-91 j55 rear 13 " brake adaptor brackets availble where??
312 Posts
hi guys
how are ya.
can any one please help advise me where i could possibly buy a set of j55 13" rear disk brake adaptor brackets from please which i want to fit on my 1991 z07 vette ??
if i managed to find these,will i loose the e brake( hand brake, what we call it here in OZ) that i have heard before mention ??
also do just order the l&r front 13" calipers to suit to fit to the rear ??
or are they different shape/design on the rear ??
any other problems i might come across ??
thanks guys
cheers
glen
Posted on: 2008/6/21 6:32
CasetheCorvetteman Re: j55 rear 13 " brake adaptor brackets availble where??
No glen you cant do that as far as i know, but why do you want to do that for? There are better options out there.
Posted on: 2008/6/21 8:04
c4-zo7-91 Re: j55 rear 13 " brake adaptor brackets availble where??
312 Posts
hi casey,
how are ya
thanks for the reply mate.
i like size look of the 13 " rotors and it would be great to have them fitted on the rear with 4 spot calipers thats all!!
some of the awsome options out there are very expensive though!!
cheers
glen
Posted on: 2008/6/21 8:37
Nah mate, too big for the rear. The J55s are only 2 piston calipers.
Posted on: 2008/6/21 9:25
bogus Re: j55 rear 13 " brake adaptor brackets availble where??
20861 Posts
The rear brakes don't do jack anyway.
When it comes right down to it, the rears account for about 20% of the stopping force. In short, they keep the rear stablized under stopping.
Too much rear brake and the car can become very unstable in a trail braking situation, re: unexpected snap oversteer.
There was someone on CF that was selling a rear brake kit that used the stock caliper to keep the e-brake and uses a Porsche caliper for stopping.
Short of all out road racing, I don't see the need or point, to be honest.
If I was going to spend the $$ on brakes, it would be in the front. Wilwood, Brembo, AP Racing... Sadly, Stoptech doesn't make brakes for the C4. At least they didn't when I checked last, but I suspect their C5 system could be retrofitted.
Posted on: 2008/6/21 18:13
312 Posts
hi andy,
how are ya!
thanks mate for your reply and help.
ok then i under stand what you are saying and thanks.
do i need any larger than 13 " size disk on front then ??
or just get better 4/6 spot piston calipers then on front and be done with it??
i have already s/s brake hoses,drm bias spring,syn dot 4 high boiling fluid already!!
and going to buy some ssbc cryco slotted rotors soon all round with hawk hp pads!!
what about a brake proporstion valve kit,any good??
just r.e my guru status,how come i am still on " newb guru"?? please,as iv noticed im up over 100 posts now and other members are on guru now,not newb guru thats all mate!!
cheers
see ya
glen
Posted on: 2008/6/21 21:12
20861 Posts
We have a bug in the ranking system... I need to figure it out!
As for brakes, be cautious of one thing - space. If you put real big brakes on, you will have a wheel fitment issue. So whatever you do it must fit the wheel combo you have selected.
Also, more pistons does not = better braking. It's about clamping force as much as anything. I don't get the feeling you are road racing, so the later GS caliper would be more than enough. IT looks nice, powercoated black with "CORVETTE" cast into it. The only fault of the C4 caliper is the design itself! The lack of a heat vent can cause them to over heat and spread open, dropping effectiveness.
I would not mess with a proportioning valve. There is one in the master already, and unless you are going road racing, it does nothing but cause wrecks. Besides, it might piss off the ABS.
If you want a nice upgrade, do something along the lines of the C5 brake upgrade.
Posted on: 2008/6/21 22:07
1Fast04Vert Re: j55 rear 13 " brake adaptor brackets availble where??
The J55 option is for 13" FRONT ROTORS ONLY. The rear rotors are the same as all other C4 brakes. Since they never made 13" rear rotors you will have to explore other options.
Posted on: 2008/6/22 1:37
312 Posts
hi 95vette,
how are ya.
thanks for the reply.
i know the j55 13" brakes came only for the front but i was hoping to modify a set to fit the rear thats all!
cheers
glen
Posted on: 2008/6/22 3:29
20861 Posts
you can fit 13" rotors to the rear... it's just whether it's worth it or not.
Posted on: 2008/6/22 4:42
312 Posts
i just like the look of the 13 " size rotor on the rear thats all!!
Posted on: 2008/6/22 5:38
Jeffvette Re: j55 rear 13 " brake adaptor brackets availble where??
Yes you can.
No it's not. You need larger in the front to compensate for the change in the rear.
Correct, you can tell the difference when racing.
Well, it helps in the fact it provides more clamping force over a larger area when you have a larger pad.
With all of that said, You can run a 13" rotor in the rear. If you are trying to retain the factory caliper for parking brake, you will need to find a 3/4" thick rotor on the rear, and have a custom hat made.
This is my rear brake set up.
13" rotor, 4 piston Brembo caliper, factory brake is retained for parking brake only.
I am running a 4 piston Brembo caliper up front with a 13.5 rotor.
Posted on: 2008/6/22 5:59
If you want to add more unsprung weight to the rear, by all means. Thats about all youre doing considering this is a street car.
Glen i dont know what wheels youve got on that car at the moment, but if they are still sawblades i dont know how big a brake youll fit under them, the C5 brakes would go very close to hitting.
Yes you can.
This car he has is a STREET CAR, its not a race car, its a massive overkill, there are much better and smarter options for the money.
Posted on: 2008/6/22 6:42
312 Posts
hi jeff and casey,
thanks for your replies guys.
jeff,thanks for the picture mate.
well i class my vette that im slowly building up as street race car actually considering it will be having approx 500 rwhp!!!
case im still running the saw blade 11" wide rims as i like the cooling effect they give the brakes and the desgin of them!!
if i use a wheel spacer with the saw blade rims
will that help give clearance for the larger calipers??
cheers
glen
Posted on: 2008/6/22 7:09
Wasn't the point, you said he couldn't, which of course he can. Sometimes a little more weight is better, especially in the back.
The man wants 13" brakes on the rear of his car, I think you're missing the point in telling him what he wants on HIS car.
And guess what, the rear brakes I showed, they are on my street car. Maybe some of us drive a little harder than you do and need the extra brake capabilities.
Posted on: 2008/6/22 7:33
20861 Posts
HP isn't the reason, it's gonna be a descision based upon driving style. If you expect to use all that power, you would want more brakes.
cheers
glen
spacers won't help. it would do very bad things to wheel geometry and potentially compromise structural integrity. In short, spacers are a bad thing... and I would avoid them at all costs. Considering the options, that would be a bad one.
I knew someone had the brake conversion... I didn't remember it was Jeff. I assume, Jeff, you saved the specs for manufacture?
Posted on: 2008/6/22 19:25
Nah, just wadded it up and threw it away today, according to Case there are better things to spend money on.
Posted on: 2008/6/22 21:45
20861 Posts
ah, got ya.
I wonder if you can scratch out an approximate design on a napkin. That would be ok.
Posted on: 2008/6/23 0:14
mst1987 Re: j55 rear 13 " brake adaptor brackets availble where??
Edmonton, Alberta, Canada
3 Posts
Jeffvette - I was wondering if you are still making the C4 to C5 brake upgrade brackets for the early C4's ?
Posted on: 2008/6/23 22:31
Yellow 1987 Z52 Roadster
L98, TPIS Miniram, BBK 52 mm Throttle Body, TPIS ZZ409 cam, TPIS chip & coated Headers, MSD Ignition, B&M 2400 stall TC, 9.5 & 11 inch Grand Sport wheels
Yes I am, send me a PM.
Posted on: 2008/6/24 5:29
CentralCoaster Re: j55 rear 13 " brake adaptor brackets availble where??
FWIW, the rears can do 50% of the work during light braking and nearly 35% at full tilt.
There is a 13x.87 rotor out there that'll fit a wilwood hat allowing you to fit the stock rear 88+ caliper but you'd need a custom adapter to mount it. I need to track it down as I need more rear bias.
Posted on: 2008/6/24 7:08
