179 user(s) are online (78 user(s) are browsing Forums)
95Vert Dim Speedo Display
Aiken, SC
440 Posts
First, I did a search for this here and did not get any hits. Tried CF as well, but they talk about bulbs around the speedometer.
What I'd like to know is if there are bulbs I can change for the digital display on my speedometer, 95 version. The actual numbers/letters are not as black as I've seen in pictures of other Corvettes. Mine look dimmer. Tough to see in daylight as well.
Any ideas? Am I looking at a new speedo?
Ralf
Posted on: 2008/6/7 5:59
95Vert Re: Dim Speedo Display
Aiken, SC
440 Posts
I'm guessing no one knows the answer or is it too soon?
Posted on: 2008/6/7 16:31
FATED Re: Dim Speedo Display
Texas
157 Posts
Hang in there. Someone will get to you that has been there before. My limited experience stops at 85.
Posted on: 2008/6/7 16:57
Aiken, SC
440 Posts
Appreciate it!
Posted on: 2008/6/7 17:04
1Fast04Vert Re: Dim Speedo Display
I will check my FSM later and see if it has any advise.
Posted on: 2008/6/7 18:33
pianoguy Re: Dim Speedo Display
Wish I could help. The background on mine dims slightly off and on while driving - I'm thinking it's a ground or something.
Posted on: 2008/6/7 18:52
bogus Re: Dim Speedo Display
20861 Posts
if the black numbers are dim, I would suspect the display itself.
The back lighting only lights the full screen so you can see it, if the black bits are dim, that means the display is suspect.
I would contact Dr Dons and see if they have any insight.
Posted on: 2008/6/7 19:11
Matatk Re: Dim Speedo Display
22814 Posts
Can the sun fade them like the digi-dashes? I know zero about the newer model dashes....
Posted on: 2008/6/7 19:14
Aiken, SC
440 Posts
I don't think they can fade, unless electronically. If I change it out, and I'm thinking just the speedo part, then I end up with new mileage is what I'm guessing.
Does Dr. Don's have a website? He fixes radios I believe, right?
Would also like to knwo what the FSM has to say if you find anything.
Posted on: 2008/6/8 2:11
