291 user(s) are online (130 user(s) are browsing Forums)
Browsing this Thread:   4 Anonymous Users
Schrade Idler pulley...
Anyone ever broken down their idler pulley? Got snappics?
Gonna' pull mine tomorrow here...
Posted on: 2015/4/24 2:34
LD85 Re: Idler pulley...
Indianapolis, Indiana
784 Posts
I have, you can buy a new bearing and repair it that way by taking the dimensions of the stock bearing and buying one online or possibly McMAster Carr.
I got one at a local distributor here in INDY
Posted on: 2015/4/24 13:24
2005/Z51
bogus Re: Idler pulley...
20861 Posts
remember... some of the pulleys are plastic. over time, they do weaken. I would get a Goodyear replacement. IIRC, the last one I got was made in the USA and had an NTN bearing in it.
Posted on: 2015/4/24 16:34
BrianCunningham Re: Idler pulley...
Last time I bought one I had to go to a dealer
Posted on: 2015/4/24 17:13
Schrade Re: Idler pulley...
Thanks there... First thought was re-packing bearings. Haven't got at it yet; are they sealed?
Posted on: 2015/4/24 18:12
784 Posts
Posted on: 2015/4/24 22:40
2005/Z51
Matatk Re: Idler pulley...
22815 Posts
Check the whole unit, though. It's not just the bearings that go bad, the tension spring goes bad as well.
http://zr1.net/forum/showthread.php?t=21365
Posted on: 2015/4/25 11:43
22815 Posts
Posted on: 2015/4/25 11:51
Thanks there Matt...
Got the tensioner off. Hard part was pulling hoses / coolant crossover. Just put them on clean with grease film a year ago.
Pulley on tensioner feels good. But that internal spring HAS to be the culprit. I sprayed it with WD-40 several times before startup, and only once was it quiet. Granted, it is a tight shot with the lube...
But this thing only has 37K.
Posted on: 2015/4/25 21:22
22815 Posts
Miles might be low, but years are not. It is said that a tensioned spring loses tension over time.
Posted on: 2015/4/26 0:54
784 Posts
That's what my wife tells Me!
Posted on: 2015/4/26 11:24
2005/Z51
22815 Posts
Posted on: 2015/4/26 11:36
CentralCoaster Re: Idler pulley...
Btdt. Changed bearing and it still squeaked, tried douching the spring, then finally replaced the whole thing. I found wet lubes would make it worse? Maybe due to attracting dust? Honestly brake cleaner or gasoline would be a better temporary fix.
But the smog pump is also a good suspect for belt noise. I just pulled that apart too. I'll post a thread soon on how easy it is to screw it up.
Posted on: 2015/4/27 5:38
20861 Posts
the tensioner is weird... it's a coil spring, but has a plastic/nylon/composite of some sort pad. I think that pad wears out, too, causing noise.
I am not a fan of messing with the tensioner.
Posted on: 2015/4/27 17:41
Well - not the best news from Marc Haibeck...
He said my pulley (from L-98), looked "ok", before he re-fitted new parts.
So I read that L-98 parts could be fitted to my tensioner. When did it get the L-98 parts? It still has only 37K on it, so this is the third???
And WD-40, one pulley @ a time, doesn't really work for diagnostic, for start-up chirping, since they're all sealed.
He said check A/C pulley next. Check it?
I tried FIRST using a hose, but could not isolate. It needs a FUNNEL on the end, but a funnel ain't got much real estate to work around in there.
IF IT IS A/C, wouldn't turning A/C on and off, WHILE IT'S CHIRPING, have an effect???
These pulleys are pretty much the same for all C4's, no?
Posted on: 2015/5/7 22:55
22815 Posts
Try a mechanic's stethoscope on the bolt holding the pulley.
Posted on: 2015/5/8 12:14
Probably the best idea. But about the fingers... Can ya' SHOW me here Matt??? Somethin' about not havin' to pull a shoe, to count to 10...................
Posted on: 2015/5/9 5:37
22815 Posts
Chuck, I don't know how far the pulley is buried in the engine bay. But a mechanic's stethoscope has a long metal rod that you place against that area you are trying to listen to. Shouldn't have to stuff any fingers down there.
Posted on: 2015/5/9 13:20
Great - another tool...
If the new tensioner doesn't get it, I'll probably be there.
Anybody got one I can BORROW? I'll pay full cost + postage up front. Cheap OR expensive, I'm runnin' out of space for once-used tools, that you have to navigate through to get to the rest of the stuff...
And gun tools / armorer's hardware is even WORSE!
Posted on: 2015/5/9 18:46
22815 Posts
Chuck...there is no such thing as too many tools! I just had to buy two new tools for my PS lines....
BTW, the cheapie HF mechanic's stethoscope is $4 which is less than postage. You could use it and give it away once done.
Posted on: 2015/5/10 3:40
Done THAT more than a few times there Matt...
Anyway; start-up on re-install. Cleaned up some parts, and set-up cams, lights, etc...
Posted on: 2015/5/13 16:30
We ain't even gettin' close to the tensioner yet.
(does anyone have intake ducting hardware painted? Sort of like Samco hoses? )
Pull A/F housing:
Vacuum debris:
Wash:
I got 2 K&N's for both other vehicles, but not this one...
Posted on: 2015/5/13 18:16
I like how the rev limiter was set by the accessories and not the engine on the LT5s
Posted on: 2015/5/13 18:38
Didn't know that there BC!
NOR did I know that the Vigilante torque convertor is marketed for 6k RPM.
But how is Accessory the limiter on this machine here? How does that work?
( I really DON'T know much... ! )
Posted on: 2015/5/13 19:50
More cleanup. Just FUN......
Posted on: 2015/5/13 20:41
Neighbor just ran his lawnmower through my front yard!!! Thanks!
But the wind is wrong!!!!!!!!!!!! Came back outside, and dust EVERYwhere!
... and stirred up the mosquitoes! Scram F*&^er! Blood Bank is down the street.
Posted on: 2015/5/13 20:58
The accessory belt won't stay on, overspeed the alternator
Some have had them to 8,000rpm
http://zr1.net/forum/showthread.php?t=1250&page=8
Posted on: 2015/5/13 21:16
Thanks there Brian...
More cleaning here... never had a K&N clean so POORLY.
4 times in the bucket, about 2.5 qts of soap total - til the filter oil on top of the water 'broke'.
Posted on: 2015/5/13 21:44
Actually getting FURTHER from the new tensioner here...
Pulling the AIR pump. Electrical, so no new belt drive configuration.
Posted on: 2015/5/13 23:43
I got lucky. DOin' sorta' what I preach most AGAINST - PLUG N PRAY diagnostics.
Put in the re-worked tensioner (after doin' some cleanup and paint), and then spun it up.
QUIET - no chirp. In fact, it spun up immediately, something it rarely does, which is strange because I did nothing else (which seems to be a common problem after so many years; even lower mile, well tuned motors). But second turn, it took a few seconds...
Now time to try and learn coding.......
I took a few more shots along the way:
AIR pump out:
and snorkel
re-coat TB Extension
Posted on: 2015/5/18 14:30
Edited by Schrade on 2015/5/18 14:45:53
Flat Black on A/F lid
Red on A/F housing (flame suit on)
Grease on pipes
Posted on: 2015/5/18 14:52
Filter coolant juice
re-fill
shave in the morning
under the chin, and don't cut your finger
Posted on: 2015/5/18 14:59
Grease on threads
set the TB Extension
di-electric on connectors
Posted on: 2015/5/18 15:07
Done.
Posted on: 2015/5/18 15:08
TommyT-Bone Re: Idler pulley...
33837 Posts
Sharp!
Posted on: 2015/5/18 16:21
Nice!
Posted on: 2015/5/18 17:13
THanks.
Just a TUNED motor.
Don't think it even has the power that yours does Brian...
Posted on: 2015/5/18 20:46
Looks good, but I'd dump the K&N. They pass way too much dirt. I think because it's impossible to evenly coat the pleats by spraying it. The peaks will always be overloaded and the sides too little. Plus on the early cars it's hard to get a good seal on the hard poly surround with only 2 bolts on the flimsy intake. I still run one though because the paper one is too tall and blocks my cold air duct.
Posted on: 2015/5/19 20:30
Missed this there CC...
Never known anyone who didn't care for K&N...
Only rap is TOO much oil - (for MAF Filament) I go VERY LIGHT on it. And directions DO say let it sit for ? hrs before install.
I do them for all my stuff. Obsessive for clean - I vacuum house A/C filter every no more than 3 days. And if you've seen my wrenchin' posts, cleaning bolt threads with wire brush, AND bolt holes too, you'll see why K&N (or Spectre / wannabe K & N).
Paper probably DOES flow better, I'm guessin'.
Anyone???
Posted on: 2015/6/3 23:50
