237 user(s) are online (102 user(s) are browsing Forums)
woody3882 Wires yellow w/black tracer ?
Florida
51 Posts
I found a factory harnessed wired plug that I cant find where it goes. The harness has 2 wires that go to a plug that is just hanging free. The colors of the wires are black and the second is yellow w/black tracer. Yes I do have both FSM's and combed through them. The location of the app 6" 2 wire harness is underhood on the passanger side in the area below the a/c heater fan motor. I did (after combing every schamatic) find a similiar wire color combo that goes to the trans fluid temp, but this is to far from that area. So if you have a 1994, please look just below the a/c fan motor, and below the heater hoses and see if you can find the destination of that wire coupling. I would greatly appreciate it.
Thanks
Stay Safe
Woody
Posted on: 2013/3/2 21:05
Calm Re: Wires yellow w/black tracer ?
Vancouver, Canada
608 Posts
Hi Woody,
Just looked on my '95 and found mine go into the bottom of the rad tank.
Posted on: 2013/3/2 22:00
woody3882 Re: Wires yellow w/black tracer ?
Florida
51 Posts
You are the man of the day.. Thanks I do appreciate it
Woody
Posted on: 2013/3/2 22:16
Vancouver, Canada
608 Posts
BTW....it is the low coolant sensor.
Glad to be of help!
Posted on: 2013/3/2 22:25
Florida
51 Posts
I just checked and my 94 does not have a connector/sensor on the bottom of the water tank, so I have to assume that the tank has been replaced or the low water sensor was an option. Anyways, my tank does not have it. but at least I know where it goes to
Thanks
Posted on: 2013/3/3 19:31
1Fast04Vert Re: Wires yellow w/black tracer ?
The sensor is actually built into the surge tank, so it about has to be there.
Posted on: 2013/3/3 19:47
BillH Re: Wires yellow w/black tracer ?
The sensor is on the outboard, rear of the tank. You have to look over the top of the a/c fan thru that small gap.
The wires should be black/yellow and gray.
Page 8A-86-1
Posted on: 2013/3/3 20:54
Florida
51 Posts
YOU ARE RIGHT.. I pulled the tank and found the opening for the sensor on the bottom of the tank, But unfortunatly the sensor on my car has been removed. I will see if I can find a replacement online.
Thanks again
Woody
Posted on: 2013/3/4 7:36
Thanks again
Woody
If you can't find new, vette2vette probably has a used one.
Posted on: 2013/3/4 15:07
