Browsing this Thread:
3 Anonymous Users
istter1 | Re: A & D ENGINES | ||
Well I guess Dave isn't reading this anymore I fibed about the oil seal my son installed it wrong |
Posted on: 2012/11/16 2:57
EngineDoctor | Re: A & D ENGINES | ||
Haha, sry Steve, havent been online much Nice to see it coming together ! |
Posted on: 2012/11/16 20:11
Hope busness is picking up Dave for you. |
Posted on: 2012/11/17 2:04
Well Dave we fired her up and broke the cam in. We will be fixing a few other little things and hope to have it out of the shop and on the road again..
Thanks for all of your hard work. |
Posted on: 2012/11/30 1:51
You are welcome Steve, and many thanks to you Sir ! Happy to see that you are gett'in her done ;) She should be a blast to drive . |
Posted on: 2012/11/30 21:45
bogus | Re: A & D ENGINES | ||
Can't wait for the driving report!!!
Posted on: 2012/12/2 19:10
Well I was out shooting my P98 when John took her out for a test drive. Stalled a couple times but that is what I brought it in for. Guess it is the part the computer talks to has 4 pins plug in that is causing it to stall only when you are driving and when comeing to a stop. Was the reason I was bring it in. John will fix that.
Big problem is the one piece rear main seal leaks at about 3000 rpms. Not at an idle. We replaced the seal that my son installed. John is going to pull the transmission and see that the one piece is conected correctly. It leaks very little. I don't want it to leak at all. John test drove it and he found out what I had told him about this transmission. Can spin on a dime in low gears and at 75 miles an hour less than 1700 rpm. Awsome gas millege. Average about 27 on freeway Dam new GMC truck only got 15.6 mpg on way to beach sat. |
Posted on: 2012/12/3 4:04
Hopefully that r/m seal just needs to be run a bit to seal properly.. You never know , if it was installed properly it should not leak though. 27mpg WOW! ;)
Posted on: 2012/12/3 4:14
The orginal window sticker says 24 14-18 cit 20-28 hwy We talked about driving it to see if it seals but haven't ever had to do before. I will talk to john who is sick of working on vet. He suggested I try that too. I want it back too. |
Posted on: 2012/12/3 4:49
I have vet at home love the sound of it. Everything works great. The throwout bearing works great everything shifts great. Lots of power and the bad part is mu uncle died and this friday will be a big Catholic funeral (x policemen) will have police escorte all that stuff. I won't be able to take a run to see about gas millege on the road for a weel or so. Thanks Dave |
Posted on: 2012/12/4 5:15
Also I am very happy that you are pleased with you stroker, and once again, thank you for letting me be of service to you !! Happy Strok'in to you Stevo ;) |
Posted on: 2012/12/4 21:01
Posted on: 2012/12/5 3:49
New project, 57' Hemi ! I'll start on the heads first, Then deal with the lower end. Customer want's to stroke-it increase stroke .
Attach file: 57' hemi.bmp (900.05 KB) |
Posted on: 2012/12/6 4:53
cool... how much can you stroke those old 392s? I assume someone makes a crank for it...
Posted on: 2012/12/8 2:34
Matatk | Re: A & D ENGINES | ||
Sorry to hear about your uncle, Steve. But glad the engine/trans are working well.
Look forward to seeing the next hemi project in photos. |
Posted on: 2012/12/8 19:41
increase stroke,then we will need pistons with a different wrist pin location to increase stroke aswell. |
Posted on: 2012/12/10 21:58
Well Dave my son went for his first drive in the vet and he mentioned wtf and omg. He realizes what kind of work you did on the engine.
Cool |
Posted on: 2012/12/10 22:24
Hahaha, cool ! Thanks guys Say hi to your son 4 me Steve. |
Posted on: 2012/12/10 22:43
May as well take a vacation.
WORK is DEAD this month |
Posted on: 2012/12/19 22:07
pianoguy | Re: A & D ENGINES | ||
I'd send you my Vette to work on if you'd move to MN ;-)
Posted on: 2012/12/19 22:25
Thanks, Piano Guy ! Time to clean & prep machines for next year I guess 34-=63=-25536
Posted on: 2012/12/19 22:39
Sorry I can't send you another one right now. My engine is great. Trying to work out electrical problems that are making the 383 run wrong. Many things to check.
Could be results of the fire still. Fan main stopped working Fan works fine replaced the relay and lamo wires melt. Like fan is drawing too many amps. Idle problem. may be dist?? |
Posted on: 2012/12/20 1:12
December is always this way at shop And yes electrical problems are a hassle.!! |
Posted on: 2012/12/20 3:27
Machining away at the cylinder head station.
Finishing the seat work, then surface decks. |
Posted on: 2013/1/24 2:09
A&D ENGINES http://andengines.com |
Cutting the seats at 4 angles, interference grind, then lapping valves to seats.
Attach file: ah1.bmp (900.05 KB) |
Posted on: 2013/1/24 2:19
The heads assembled & vac tested, now to set ring gaps in cylinder bores , then final engine assembly.
Attach file: ah10.bmp (900.05 KB) |
Posted on: 2013/1/25 2:49
Ring end gaps are set.
Attach file: sb10.bmp (900.05 KB) |
Posted on: 2013/1/25 2:54
I want to come work in your shop for a day. You wouldn't even have to pay me
Posted on: 2013/1/25 2:58
Haha, You have an open invitation Matt!, ANYTIME ;) Attach file: yota.bmp (900.05 KB) |
Posted on: 2013/1/25 5:30
After owning Linda for 28 years, she drove off into the sunset, under her own steam, and on her way to Switzerland
Farewell Linda , It was fun to own you ! Attach file: lk.bmp (900.05 KB) |
Posted on: 2013/3/11 0:12
Congrats on the sale...I'm sure if the new owner is willing to ship it overseas it will be well cared for!
Posted on: 2013/3/11 2:51
Dave motor is as great as you told me.
Can't say thanks enough |
Posted on: 2013/5/21 4:54
Glad it worked out for you Steve
Posted on: 2013/5/21 18:02
Hello Guru friends!
I am trying to revive my Face book page , and would like your support.. Just go to "A&D Engines" and click like Feel free to comment etc on my page, and I thank you for your support Guru's! |
Posted on: 2013/8/13 3:53
Done! Now let's see some engine porn!
Posted on: 2013/8/13 22:27
Haha. Thanks Matt !! |
Posted on: 2013/8/13 22:38
Thanks Andy Bogus & Matthew R. liking my page !
Posted on: 2013/8/14 21:27
Working on pictures
Posted on: 2013/8/15 4:31
Dave got 5000 miles on the 383 stroker and it is costing me tires. Have nothing but praise for the engine you built for me. Need any recomendations tell them to call me.
Posted on: 2013/8/15 18:17
Hi Steve, great to hear from you & thank you for
the praise ! ;) !! Please go to my facebook page A&D Engines and click like and feel free to comment there on the engine I built for you, and thank you again for your business & support. I do have a picture of your car on there! Unfortunately only a couple of Guru's have done so |
Posted on: 2013/8/15 19:38
Calm | Re: A & D ENGINES | ||
I 'liked'. But only because I anticipate much more machine work porn. |
Posted on: 2013/8/15 20:54
1995 Forged 385 ZF6 227/234 1.6 FIC30# MSD BBK SS SLP Bullets X-Pipe DynoMax |
Appreciate it Calm I'll try and get some sexy machine work porn out there ! |
Posted on: 2013/8/15 21:04
You need more views on Face book
Posted on: 2013/8/30 3:42
Yes I know! The page has only been up a few weeks, thanks for liking & commenting on page Steve,and for allowing me to use your pics too.
Posted on: 2013/8/30 19:02
