205 user(s) are online (80 user(s) are browsing Forums)
Assembly Line Diagnostic Link
Frank Fog lamps
188 Posts
Finally able to get to fixing my fog lights (driving lights?) and this it what I get when I pulled the socket out. Please see photo. All help is appreciated.
Posted on: 2012/9/6 0:21
Frank Re: Fog lamps
188 Posts
Having trouble downloading photo. The end looks like its plugs into a socket.?
Posted on: 2012/9/6 0:34
BillH Re: Fog lamps
How are you downloading Frank?
If you are doing it from your computer, the photo size may be too big.
Posted on: 2012/9/6 0:36
Frank Re: Fog lamps
188 Posts
jpg  P1410981.JPG (170.84 KB)
6042_5047f184a6500.jpg 1000X750 px
Posted on: 2012/9/6 0:43
Frank Re: Fog lamps
188 Posts
Thanks BillH. Had to copy into another program. Here it is.....
Posted on: 2012/9/6 0:44
Matatk Re: Fog lamps
22815 Posts
Not exactly sure what your question is? It looks like the bulb is missing. It should look like this:
[url]=http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={928ee651-cc8e-405c-8fe0-a127d58e0f14}&gid={db44283c-e462-4f08-bc42-2e35febe716e}&GroupName=Park+%26+Fog+Lights&pname=84-90+Park%2fTurn%2fFog+Light+Bulb&Referer=&Alias=&ptct=SGR-SR&CTitle=&[/url]
Posted on: 2012/9/6 3:21
Frank Re: Fog lamps
188 Posts
Thanks for your response and the picture. I was confused at the connector/bulb socket. Never seen one like that till now. Thanks again.
Posted on: 2012/9/6 22:44
bogus Re: Fog lamps
20861 Posts
you can get those bulbs at Autozone... there is a 35 watt, stock rating, and a 50 watt, get the 50 watt, I will dbl check the numbers tonight.
Posted on: 2012/9/7 1:09
bogus Re: Fog lamps
20861 Posts
well... perhaps 1984 fog light bulbs are not available at Autozone...
Posted on: 2012/9/7 4:27
22815 Posts
The 50 watt is brighter, I have those in my 89. You may have to run a 5 amp higher fuse (15 vs 10 I think off the top of my head). Make sure your wiring is in good shape, first, the higher wattage can fry wires.
Posted on: 2012/9/7 15:04
Frank Re: Fog lamps
188 Posts
Thanks for your inputs. I'm going to the parts house on Monday. I'll post bulb numbers if/when I get them.
Posted on: 2012/9/8 3:19
22815 Posts
880 is the stock 27 watt bulb.
893 is 37.5 watts.
885 is 50 watts.
Posted on: 2012/9/8 13:46
