273 user(s) are online (124 user(s) are browsing Forums)
1st Gear: 1.76/1.82
2nd Gear: 1.00
- 14 Bolt Pan.
- Vac...
Frank Fog lamps
188 Posts
Finally able to get to fixing my fog lights (driving lights?) and this it what I get when I pulled the socket out. Please see photo. All help is appreciated.
Posted on: 2012/9/6 0:21
Frank Re: Fog lamps
188 Posts
Having trouble downloading photo. The end looks like its plugs into a socket.?
Posted on: 2012/9/6 0:34
BillH Re: Fog lamps
How are you downloading Frank?
If you are doing it from your computer, the photo size may be too big.
Posted on: 2012/9/6 0:36
Frank Re: Fog lamps
188 Posts
jpg  P1410981.JPG (170.84 KB)
6042_5047f184a6500.jpg 1000X750 px
Posted on: 2012/9/6 0:43
Frank Re: Fog lamps
188 Posts
Thanks BillH. Had to copy into another program. Here it is.....
Posted on: 2012/9/6 0:44
Matatk Re: Fog lamps
22815 Posts
Not exactly sure what your question is? It looks like the bulb is missing. It should look like this:
[url]=http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={928ee651-cc8e-405c-8fe0-a127d58e0f14}&gid={db44283c-e462-4f08-bc42-2e35febe716e}&GroupName=Park+%26+Fog+Lights&pname=84-90+Park%2fTurn%2fFog+Light+Bulb&Referer=&Alias=&ptct=SGR-SR&CTitle=&[/url]
Posted on: 2012/9/6 3:21
Frank Re: Fog lamps
188 Posts
Thanks for your response and the picture. I was confused at the connector/bulb socket. Never seen one like that till now. Thanks again.
Posted on: 2012/9/6 22:44
bogus Re: Fog lamps
20861 Posts
you can get those bulbs at Autozone... there is a 35 watt, stock rating, and a 50 watt, get the 50 watt, I will dbl check the numbers tonight.
Posted on: 2012/9/7 1:09
bogus Re: Fog lamps
20861 Posts
well... perhaps 1984 fog light bulbs are not available at Autozone...
Posted on: 2012/9/7 4:27
22815 Posts
The 50 watt is brighter, I have those in my 89. You may have to run a 5 amp higher fuse (15 vs 10 I think off the top of my head). Make sure your wiring is in good shape, first, the higher wattage can fry wires.
Posted on: 2012/9/7 15:04
Frank Re: Fog lamps
188 Posts
Thanks for your inputs. I'm going to the parts house on Monday. I'll post bulb numbers if/when I get them.
Posted on: 2012/9/8 3:19
22815 Posts
880 is the stock 27 watt bulb.
893 is 37.5 watts.
885 is 50 watts.
Posted on: 2012/9/8 13:46
