214 user(s) are online (102 user(s) are browsing Forums)
383tpimachine Custom Cam Spec.
Corpus Christi
976 Posts
Friend of mine does custom cams. To get the most out of your setup an off the shelf cam just does not do it.
His prices are competitive and each cam is custom taylored to the customers wants and application.
Volatile Cams will be doing all of my cams from this point forward.
Email them for anything you need valvetrain related
volatilecams@gmail.com
jpg  volatilesignature-2.jpg (28.68 KB)
2180_4f22235e31141.jpg 464X169 px
Posted on: 2012/1/27 4:11
1970 El Camino-Awaiting LSX
bogus Re: Custom Cam Spec.
20861 Posts
Are they in Texas, local to you?
Posted on: 2012/1/27 17:29
383tpimachine Re: Custom Cam Spec.
Corpus Christi
976 Posts
Yessir. Located in Corpus Christi.
Posted on: 2012/1/27 18:16
Matatk Re: Custom Cam Spec.
22814 Posts
I know Will uses a custom grinder, too. I wonder how they compare price/quality wise?
Posted on: 2012/1/27 19:10
EngineDoctor Re: Custom Cam Spec.
La Habra Ca.
791 Posts
I prefer custom cams aswell opposed to off the shelf stuff.
I've been using Joey @ www.americancustom.cam
for 30 yrs, never got a bad cam... I just tell him what I am working on , give him the specs. I want and that's it! Then again I do give my customers other cam options too
Posted on: 2012/1/27 22:16
Corpus Christi
976 Posts
This company, Volatile, and its owner, Russ, have helped me learn more than I can even comprehend sometimes and worked with me for a month specing out a cam that would work well for autox/roadracing in my vette. He devotes hours on end to each cam all based on head flow, max rpm, NA or FI, Injection or carb, nitrous.
He always recommends the 4/7 swap in Gen 1 and 2 sbc which is also the plan.
Posted on: 2012/1/28 13:47
La Habra Ca.
791 Posts
IMHO, I suggest that regardless of what cam you get, take the time to have an expert check it out before you install it. Seen lots of issues in this dept .
jpg  432258_2355038574001_1791312576_1559499_1754577965_n.jpg (27.25 KB)
7794_4f3b20503fc27.jpg 480X640 px
Posted on: 2012/2/15 3:02
LD85 Re: Custom Cam Spec.
Indianapolis, Indiana
784 Posts
Only used Bullet Cams so far, good to know there's another.
Posted on: 2012/2/16 18:00
2005/Z51
