219 user(s) are online (90 user(s) are browsing Forums)
Frank 1984 Driving lights
188 Posts
This is going to show my new-be-ness to the nth degree but I have to ask (there are not stoopid questions.......) On the dash just to the right of the head light switch there is a switch that doesn't do anything. My thoughts were that this is for the Driving lights. If it is and its just a matter of changing out bulbs how do I get to them? No screws on the outside and no access on the inside. Thanks.
Posted on: 2011/12/23 22:49
Frank Re: 1984 Driving lights
188 Posts
I found the parking light bulbs (amber ones) and they look easy enough. But when I pulled the driving lights plugs out there wasn't a bulb on the end for either side.?
Posted on: 2011/12/23 23:03
CentralCoaster Re: 1984 Driving lights
There are 3 sets of lights on the front of the car. For the sake of this thread, I'll call them this:
Headlights...
Fog lights (white)
Parking lights (yellow)
The yellows come on when you have the headlight knob at least one click out. (Two clicks out turns the headlights on also.)
The white fog lights come on when you have the headlignt knob at least one click out AND the switch turned on.
They can be gotten to from under the hood. There is a grey plastic bulb holder that turns 90* and locks into place in the housing. It has a flat part to grab onto to twist and remove. The bulb attaches to the end of it. It's sorta buried under there.
Posted on: 2011/12/24 0:47
188 Posts
Thanks. I twisted and pulled the fog light connections out and there are no bulbs (a definite Eureka moment). The end looks like a wire connection instead of a bulb socket?
Posted on: 2011/12/24 2:03
Matatk Re: 1984 Driving lights
22816 Posts
Sounds like Bubba was there before you!
Posted on: 2011/12/24 12:53
1Fast04Vert Re: 1984 Driving lights
How about a picture of it?
Posted on: 2011/12/24 13:53
bogus Re: 1984 Driving lights
20861 Posts
it should be a socket... but an open socket. The bulb doesn't have a plug on it, it has exposed wires and gets plugged in.
I wish I had a picture...
Posted on: 2011/12/24 18:31
joeld Re: 1984 Driving lights
Posted on: 2011/12/24 19:22
captmike13 Re: 1984 Driving lights
Hillsboro Mo
2166 Posts
I'll see if I can get a pick tomorrow from my 85.
Posted on: 2011/12/25 2:30
13 GMC 3500 dually
captmike13@yahoo.com
22816 Posts
The light bulb should look like this:
That will give you an idea of the socket - go to rock auto and it will show you.
Posted on: 2011/12/25 3:02
Hillsboro Mo
2166 Posts
Posted on: 2011/12/25 3:06
13 GMC 3500 dually
woody1987 Re: 1984 Driving lights
46 Posts
pulled mine the other day because the parking bulb was out just to ck them out. this is one area that the aftermarket could really make an improvement on. would be nice if someone made a reflector type replacement housing. there was a replacement silverstar ultrabright 880 on clearance at oriellys for 12 bucks. figured what the heck i'll try it. couldn't really tell the differance at all. dread pulling the drivers side housing as it is just sitting in the bumper appears the mounting bracket is broken. will probably just wait until i upgrade the bumper cover to tackle this one. hope everyone has a merry xmas and a happy new year1
Jim
Posted on: 2011/12/25 13:09
188 Posts
Perfect picture. I'm missing both bulbs... Just picked her up in August so its taking awhile to go through everything. Thanks.
Posted on: 2011/12/29 6:08
188 Posts
GREAT information. Thanks. Turns out I'm missing both bulbs. ?
Posted on: 2011/12/29 6:09
188 Posts
This information coupled with the picture matatk sent and captmikes link explains it all. Thanks guys. This is a great site.
Posted on: 2011/12/29 6:12
CorvetteArchives Re: 1984 Driving lights
65 Posts
This may help too if you want to wire them to be on withOUT your headlights popped up http://corvette1984.freewebtools.com/ ... /DrivingFogLights/FL.html
And while you're in there...why not just upgrade to HID? :-)
http://www.corvettehid.com/cart/index ... bef3bd8c4f19c289f8aa97d1c
Posted on: 2012/1/1 6:15
188 Posts
Thanks. Looks like a good idea.
Posted on: 2012/1/4 5:37
Hillsboro Mo
2166 Posts
My 85 don't need to have head lamps popped up. They work on parking light setting also.
Posted on: 2012/1/4 11:07
13 GMC 3500 dually
