251 user(s) are online (120 user(s) are browsing Forums)
Fredbird 1991 Injector Connector boots
San Antonio, Texas
103 Posts
I have a 1991 with the stock L98 engine... My question is simple... Should my injectors have a boot on top of each of the connectors that the wires are in? Or did they stop doing that on the later L98 engines?
Reason I ask, is my dad has an 86 and each injector connector has a rubber boot that goes on top of each connector and covers the wires. Looks really nice.
If it's supposed to have those... Anyone know where I can get them?
Posted on: 2011/7/29 23:59
flyboy Re: 1991 Injector Connector boots
Mine doesn't have any boots and I'm pretty sure it came that way from the factory.
Posted on: 2011/7/30 0:43
Woodstock Re: 1991 Injector Connector boots
Bremen/Germany
369 Posts
No boots on my 91 either. Certainly stock, because I got it this way new in 91.
Posted on: 2011/7/30 11:04
91 convertible
Matatk Re: 1991 Injector Connector boots
22815 Posts
I've never seen those...I'd like to see a picture if you can get one.
Posted on: 2011/7/30 12:30
Fredbird Re: 1991 Injector Connector boots
San Antonio, Texas
103 Posts
Here's the picture you wanted...
Just thought they looked nice. So was curious if the previous owner of mine just cut them off...
jpg  Injector Boot.jpg (718.37 KB)
4126_4e3973bed2e12.jpg 1632X976 px
Posted on: 2011/8/3 16:14
22815 Posts
I wanted to revisit this. Joe and I were talking the other day and figured the boots have to be factory based on the way they are on the harness. They are one piece (no open seam), and there is no way to slip them over the injector plug.
Fast forward to yesterday, and I was looking at a guy's 86 - sure as heck, there were the injector boots on his car. So it seems they were factory on early cars, but I don't know the year range. Maybe we can get a consensus of when they were. I've seen 88s that didn't have them and I know my 89 doesn't currently. So I'm assuming a year range of 85-87, but it might be more narrow than that.
Posted on: 2011/8/13 22:23
corvetteronw Re: 1991 Injector Connector boots
Lowell, MI
I owned an 86E a long time ago but don't remember any being on there. My memory is getting bad though so don't quote me.
I do know that they were not on the 87 I owned and are not on the 91 I now own.
Very interesting!
Posted on: 2011/8/19 0:36
Those boots sure are purty. Wish they hadn't stopped using them.
Posted on: 2011/8/19 1:36
JeffK Re: 1991 Injector Connector boots
High Point, NC
1440 Posts
I'm with Joe.
Posted on: 2011/8/19 11:17
mikeV Re: 1991 Injector Connector boots
Top of the world Ma
158 Posts
Early '86
[IMG]http://i246.photobucket.com/albums/gg81/mikemark/001-7.jpg[/IMG]
Going to investigate this at Carlisle next weekend
Posted on: 2011/8/19 20:00
Top of the world Ma
158 Posts
OK...did some detective work at Carlisle. It appears that these boots were used in '85 and '86 only and no one could explain why. When ever I had time to find Gordon to ask him about it he was doing a seminar or busy at his booth.
My search continues to check for late '86 cars with aluminum heads.
Posted on: 2011/8/29 9:15
22815 Posts
Thanks, Mike! Could be isolated to iron headed motors? The world may never know....
Posted on: 2011/8/29 11:41
Top of the world Ma
158 Posts
Nope not isolated.. Just found some pics of Aluminum head '86 with the boots so it appears to '85 and '86 only.
Probably a Vendor change but most likely a cost cutting change.
Posted on: 2011/8/29 11:47
Well, I had to do something, so I used some split cable sheathing and vinyl vacuum caps to tidy up the wiring a bit.
jpg  P1010001.JPG (133.02 KB)
1735_4e6a80b2a5242.jpg 640X480 px
jpg  P1010003.JPG (145.42 KB)
1735_4e6a80dce64fe.jpg 640X480 px
jpg  P1010009.JPG (126.70 KB)
1735_4e6a80f3856f0.jpg 640X480 px
Posted on: 2011/9/9 21:12
22815 Posts
Two things Joe:
1) That doesn't surprise me you had to do that
2) Looks great!
Posted on: 2011/9/10 11:39
