216 user(s) are online (104 user(s) are browsing Forums)
Matatk, more...
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
383tpimachine Procharger help
Corpus Christi
976 Posts
I know at least one member here is running a centrifigal sc.
My question are:
Do I need a reverse rotation on my 85?
will the pb600 support 750rwhp?
Can the sc fit easily where the air pump used to go?
thanks
Posted on: 2011/6/8 3:21
1970 El Camino-Awaiting LSX
bogus Re: Procharger help
20861 Posts
The only one I can answer, or even partially answer, is #3.
I don't think it will fit where the air pump was. The blowers for L98s came with rerouted everything, and IIRC, the blower was mounted so the pulley FACED the engine.
Tommy has a blown L98, I am sure he can help a little.
Posted on: 2011/6/8 3:41
383tpimachine Re: Procharger help
Corpus Christi
976 Posts
I plan on fabbing up my own routing with my custom hood so would just be buying the HU. Just want to make sure I will be buying the right one for what I want to do.
Thanks bogus
Posted on: 2011/6/8 3:51
tjpreul Re: Procharger help
Procharger has the P600B listed as supporting 775hp. The picture looks like you turn the alternator around to make the room for the head unit. That unit is also reversable. I would call Procharger, they are very helpful. Here is a link for specs.
http://www.procharger.com/models.shtml
Posted on: 2011/6/8 3:52
20861 Posts
This is an F-body, but it's an idea...
http://www.procharger.com/GM/TPIF-body_UH.shtml
Posted on: 2011/6/8 3:53
Corpus Christi
976 Posts
http://www.procharger.com/GM/TPIVette_UH.shtml
Looks like the P1sc-1 is what I would be better off going with. Just incase I want to grow a lil.
Another question:
Belt slip issues with the 6 rib? How about the 8rib?
Posted on: 2011/6/8 4:12
Corpus Christi
976 Posts
Wonder if the LT1 kit would work on a L98. It looks much nicer than the L98
Posted on: 2011/6/8 4:15
TommyT-Bone Re: Procharger help
33834 Posts
L-98 mounting options are extremely limited. Every one I've seen has been mounted with the alternator reversed, unit on the drivers side. My intercoolers are located at the front of the wheel wells where the radiator overflow and air canister were. Tech support and questions are readily answered by ProCharger techs at the website and possibly by phone. I didn't mount my system but if you need pics of anything let me know.
Posted on: 2011/6/8 11:49
33834 Posts
Here are some from when I first got the car.
Posted on: 2011/6/8 12:03
Another question:
I am going to use the P-1sc. I like that it has a self contained oil system and doesn't have to be plumbed into the engine oil. That one isn't listed for the l98, but should be able to use it. I have asked Procharger on the belt slip issue. They said they dont' have issues with it. As Tommy said their tech is really helpful. I have asked several questions myself.
Posted on: 2011/6/8 13:30
Corpus Christi
976 Posts
Thanks tommy.
What do your IAT look like on a 80-100* day?
What is mounted in the stock airbox location? oilcooler? transcooler?
Seems like all the kits are for speed density correct? No more crappy maf
Posted on: 2011/6/8 13:58
33834 Posts
Thanks tommy.
Never checked IAT. The metal container mounted in front of the airbox is is the relocated coolant overflow.
Posted on: 2011/6/8 14:38
BrianCunningham Re: Procharger help
All this time I never knew your car was supercharged
Nice intercooler install
If I go that route that's a nice way of doing it
Posted on: 2011/6/8 16:40
LD85 Re: Procharger help
Indianapolis, Indiana
784 Posts
What is a realistic cost total for a SC mounted on an L98?
Also, I have 430rwhp/460/rwtq, what RWHP could I see realistically with a minimal 8-psi boost? 25%. 30% ?
Posted on: 2011/6/8 20:34
2005/Z51
33834 Posts
Contact ProCharger for latest pricing and needs.
Here's a comparison chart and hp gain reference
http://www.procharger.com/h2hdt.html
Posted on: 2011/6/8 21:03
33834 Posts
Oh yes you did ......
http://www.corvette-guru.com/modules/ ... id=112702#forumpost112702
Posted on: 2011/6/8 23:31
784 Posts
I did this afternoon, I think this is the direction I want to go , gotta read some more and do some shopping!
Posted on: 2011/6/9 0:42
2005/Z51
Corpus Christi
976 Posts
A cam change will be in order for a centi sc and a 406 with 8lbs should easily make 550+ rwhp
Posted on: 2011/6/9 4:53
What's your compression ratio?
Cast or forged pistons?
Posted on: 2011/6/9 16:32
Corpus Christi
976 Posts
I wont be putting it on this 383.
I have another block sitting. will build it all forged. 9.3-9.6 cr depending on the heads I decide to put on it.
Figure with the right cam and some TEA heads I can beak 500rwhp on 5-6lbs and 600 on 12lbs
Posted on: 2011/6/10 5:05
What's your best run?
Any dyno #'s?
Posted on: 2011/6/10 21:48
Sounds like a good plan
A good blower cam is a must
As well as finding someone that can tune it
Posted on: 2011/6/10 21:50
Corpus Christi
976 Posts
Turns out the p1sc is a no go. D1sc is gonna be my line of action.
I have a great local tuner. Just hope the stock cpu can handle it.
Posted on: 2011/6/11 4:08
784 Posts
Thanks guys for the help, I am going to shop for a Bow Tie block, use my forged 406 parts, probably will change the rods, get the cam that Pro Charger suggests, build the block and rotating assy rock solid, and go for 8-10 psi boost.
I drove 5-hours each way to the Hot Rod Power Tour Thursday/Friday and I saw a lot of craapped out cars on the way, I was pretty happy that my car took the trip with ease, and I was getting 40MPG with my TKO 600 at 70 MPH / 2100RPM
My goal will be to have a dependable setup with out dinking around with it constantly.
What type of maintenance is there on these Superchargers?
Posted on: 2011/6/12 2:36
2005/Z51
Procharger has two options. Self contained or plumbed into the engine oil. I prefer the self contained, you don't have added lines. Plus added heat from the unit. I think it takes about 1/2 hour to change the oil in them.
As long as you don't go crazy with the amount of boost, or push it to the extreme you will be fine. For my LT1 I am going for 9-9.5cr w/ 10-12psi. Procharger has it running 8psi on 10.5cr. The cam is very mild (basically stock numbers) if ran by itself.
Posted on: 2011/6/12 4:28
Corpus Christi
976 Posts
How much does your car weigh to be knocking down 40mpg?
putting around everywhere I ALMOST get to 17mpg
Posted on: 2011/6/12 5:28
784 Posts
the 40mpg was only interstate driving
[IMG]http://i556.photobucket.com/albums/ss8/LAPCO/50172cc8.jpg[/IMG]
Posted on: 2011/6/12 11:31
2005/Z51
