flyboy | Rehabbing the "halo" cover | ||
My halo covers had some damage, so I purchased a used right side and repaired the left. There is no filler that adheres well to polypropylene so I had to pop-rivet some sheet metal for backing and cross my fingers with the epoxy. Paint would not have produced the desired result, so I covered with ultra leather using spray adhesive. Turned out even better than hoped for.
Posted on: 2010/12/28 2:05
bogus | Re: Rehabbing the "halo" cover | ||
looks VERY nice!!!!
Posted on: 2010/12/28 2:11
BillH | Re: Rehabbing the "halo" cover | ||
Looks great, Joe.
Want to share some info on ultra leather? Never heard of it. Looks very nice, easy to conform. It's not a product from Ultraman is it? ![]() |
Posted on: 2010/12/28 2:17
flyboy | Re: Rehabbing the "halo" cover | ||
Thanks. It feels like glove leather. Used for upholstery. About a mm thick. The thin fabric backing gives it a little stretch lengthwise but not across the width. 3M high strength spray adhesive, coat both surfaces, kind of tricky, (once it's grabs, that's it) but I have a lot of experience with contact adhesives. Here's where I bought it.
http://www.fieldsfabricsonline.com/Ul ... -Reinforced-HP_c_340.html |
Posted on: 2010/12/28 2:31
j3studio | Re: Rehabbing the "halo" cover | ||
Interesting ...
... nice work! |
Posted on: 2010/12/28 2:44
Matatk | Re: Rehabbing the "halo" cover | ||
Wow that looks great. Just what I need for my damaged halo pieces, I believe.
Matthew |
Posted on: 2010/12/28 2:56
Ultraman | Re: Rehabbing the "halo" cover | ||
I'm thinking I should be getting some type of royalty from it, bit I'm still trying to figure out what a halo cover is! It looks good, nice work! |
Posted on: 2010/12/28 4:05
don't worry, you still have time to register Ultrawhips and Ultrachains. |
Posted on: 2010/12/28 4:09
What did you do with the garment hook? |
Good eye. Garment hook delete.
Posted on: 2010/12/28 4:19
pianoguy | Re: Rehabbing the "halo" cover | ||
Outstanding! Have I ever mentioned that you have waaaaaaaaaaaaaaay too much time on your hands? ;-)
Posted on: 2010/12/28 4:27
good idea. I like that. Lots!!! |
Posted on: 2010/12/28 4:30
JeffK | Re: Rehabbing the "halo" cover | ||
That looks great! I was just thinking the other day that I wished there was a write up somewhere about wrapping those pieces.
Posted on: 2010/12/28 12:42
Joe, Do you think that would stretch over the corners of the console lid?
Posted on: 2010/12/28 13:56
Definitely. I tried with a scrap on a similarly shaped corner.
Here's a detail of the inside. |
Posted on: 2010/12/28 14:57
I might have to get some to play with. I was thinking about getting a cover when I order a shift boot from Redline but think that the ultraleather glued down may be better.
Posted on: 2010/12/28 15:04
Suggestion - when you put it back together, use stainless steel screws. It will look sweet against the black leather.
Posted on: 2010/12/28 18:40
That garment hook is a stunningly useless component ... |
Posted on: 2010/12/29 2:47
After a near disaster on the left hand side, I managed to cover four pieces. I think I'll quit while I'm ahead.
Posted on: 2010/12/29 14:07
That does look really good.
Are you using regular 3M spray adhesive? |
Posted on: 2010/12/29 14:11
I used the "hi-strength 90". Coat both sides, heavier on the fabric to allow for absorbtion. I held the pieces upside down while covering and started from the end to minimize the risk of accidental contact.
I scrubbed the pieces in a TSP solution to clean. Lightly sand, then I wiped them with some ketone which actually started to soften the surface. Whether that helped with adhesion or not, on an experimental piece, when I pulled the ultra leather off, some of the poly actually pulled off with it. It's a permanent bond, I believe. |
Posted on: 2010/12/29 14:44
rklessdriver | Re: Rehabbing the "halo" cover | ||
That looks very nice.
I could have really used your skills back when I bought my Porsche 928... Will |
Posted on: 2010/12/29 17:56
89Vette | Re: Rehabbing the "halo" cover | ||
I can't figure out their pricing. How much does $66 buy?
Could this stuff be used to cover door panels? (IOW how much curve stretch is present?) Do you use a hair dryer or heat gun to stretch/mold? |
Posted on: 2010/12/30 4:21
383 stroker -- Semi-Siamesed SLP long-runner intake, AFR 195's, 4-2-1 headers, and a SR cam. ZF6 short-throw shifter. Custom body/interior. |
Looks to me like it would be for a yard but looking around, the prices are all over the place. One marine shop wants $88 plus a 5 yard min. A good color chart. http://www.gulffabrics.com/ultralht.htm Some good reading: http://www.hotrodders.com/forum/gsear ... raleather-67590.html#1185 I did a search and didn't come up with any vendors other than Joe's link. But it's still interesting stuff. I think it would work well on a door panel. |
Posted on: 2010/12/30 13:51
1 Yard=36X47-54".
I think so. See photos. See posts 4&15. I didn't use any heat. The fabric backing is the limiting factor for stretch. |
Posted on: 2010/12/30 13:58
VetteMed | Re: Rehabbing the "halo" cover | ||
Nice job... will have to keep this in mind for future projects.
Posted on: 2010/12/30 18:41
