NC Kid | Who has used BBK Throttle bodies | ||
Whos used them. Do they have issues? Gotta get a new TB so I am upgrading it to a 52mm. TPIS wants 600 without a core and my core is not rebuildable(its crap!). BBK is half that price...Some people have told me BBK TB's are awful. Thoughts on there design flaws/cons for a C4 Corvette....
No, don't bring up the your wasting your money on a bigger TB. That is not what I am asking. I expect no gains from going bigger. I just want a new TB plus I am upgrading stuff but thats irrelevant. Just need to know if BBK is good or bad. Thanks! |
Posted on: 2010/11/18 15:40
flyboy | Re: Who has used BBK Throttle bodies | ||
No complaints with my 52mm BBK.
Posted on: 2010/11/18 15:59
Vetron87 | Re: Who has used BBK Throttle bodies | ||
My neighbor installed the 52mm BBK on his 88. He has no problems! He installed it in 08. Everything is good. I noticed his 88 idles really well and has great throttle response. Hope this helps
Posted on: 2010/11/18 16:29
Bone stock 87 conv. |
pr0zac | Re: Who has used BBK Throttle bodies | ||
i and a few other have a professional products tb.. mines been on the car for 3 or 4 years without issue
Posted on: 2010/11/18 21:57
biggrizzly | Re: Who has used BBK Throttle bodies | ||
I am far from a Guru and installed the Professional Products TB, made the adjustments needed based on the FSM and the car started right up. Has been working very well for the few thousand miles I put on the engine prior to last June. It appears to have good workmanship, very nicely polished, and works great for half the price. |
Posted on: 2010/11/18 22:11
CentralCoaster | Re: Who has used BBK Throttle bodies | ||
Bump... how did you guys get the intake boot to fit over your Professional Products TB?
I was told it was the same casting as BBK. My plastic 85 boot won't fit, with or without the heat gun. |
Posted on: 2010/12/16 0:29
Weavsvet | Re: Who has used BBK Throttle bodies | ||
I agree. I had a BBK 52mm but never could get the thing to idle right even after doing the IAC mod on it. The PP 58 I'm using now does much better. It also has the IAC mod done to it. IAC settings are crucial on any of these after market TB's. IIRC my counts ended up around 18-20 at idle. |
Posted on: 2010/12/16 0:42
1996 Corvette Coupe,AFR 195 street Eliminators,Edelbrock LT4 Air Gap intake manifold,9.5" 2800 stall,TPIS LT headers,Bullet 226/230.565.565/111 lsa cam,1.7 Scorpion rr's,EWP, X Pipe, Stock Exhaust,Elec.Cutouts,Dana 44/3.45, Tune by Wester's Garage |
vetteoz | Re: Who has used BBK Throttle bodies | ||
File the lip off so it is the same as stock TB Quote:
Same here .Had BBK 58mm on several engines, no problems. IAC counts < 20 Only thing I will note is the BBK seem to have stiffer than stock spring ,making low speed part throttle tip in hard. |
Posted on: 2010/12/16 0:53
i have seen bbk tbs and they have a seemingly larger lip then my PP. i don't have any trouble getting my bellow on or off and nowhere near the fun a bbk is.
Posted on: 2010/12/16 1:03
WW7 | Re: Who has used BBK Throttle bodies | ||
Posted on: 2010/12/16 3:23
Ok, now I remember the hold up.
I spoke with PP on it awhile back and he said if I file on it then I'm up shit creek if I wanted anything on the warranty. But now that it's sat on the shelf for 2 years it's a non-issue. Grind away. |
Posted on: 2010/12/16 4:12
RickAnthony | Re: Who has used BBK Throttle bodies | ||
ASE Master Certified
running a BBK 52mm on my 95' I think since around 2004.. no issues here.. and as for idle, it idles pretty well but I also have a hot cam in it and it could probably use a better tune..
Posted on: 2010/12/16 4:50
383tpimachine | Re: Who has used BBK Throttle bodies | ||
I have a stock 48mm sitting or a 58BBK I would sell. I have the BBK on now and while the throttle response is "better" the stock was much easier to cruise at lower speeds
Posted on: 2010/12/16 5:17
85RedSled | Re: Who has used BBK Throttle bodies | ||
Hey WW, you got any experience with Xtreme-FI? Feedback looks good and it seems they offer quite a few different manufacturers throttle bodies.
Posted on: 2010/12/17 15:05
1985 4+3 Coupe, Bright Write me a ticket RED |
Kevin - I just saw your question about the PP Throttle Body. On my 94 - the intake boot fit without grinding. I lubed it up a little bit and it pulled on with some effort. Once I got in place I cranked down on the band clamp. I have since removed and replaced it several times without any extra force to get it on. |
Posted on: 2010/12/17 15:20
I have no personal experience, but I have talked to a few people that I trust on the other forum and they have used there TBs with no problems...WW |
Posted on: 2010/12/17 15:32
JeffK | Re: Who has used BBK Throttle bodies | ||
+15-20hp on stock motor? Is that a realistic claim?
Posted on: 2010/12/17 16:03
I asked Mick (mseven) the same question because I was going to get one, and he said I wouldn't get that much .Im sure it depends on the motor your putting it on but most companys exaggerate there numbers..WW |
Posted on: 2010/12/17 17:14
On a Solid roller 434 with 18* heads MAYBE. |
Posted on: 2010/12/17 17:21
I didn't think so either. Damn with that and an air foil you'd get like an extra 50 hp right...lol
/End threadjack. |
Posted on: 2010/12/17 17:28
bogus | Re: Who has used BBK Throttle bodies | ||
What I am curious about is how your old TB can be so crap that it can't be used as a core? I mean, think about that... did a truck fall on it? Were the ports crushed by a falling meteorite? Did it get soaked in acid? They don't use much more than the actual code throttle body, bore it out and put in new guts. This is like saying that sand isn't a good core for glass... how can you break sand? |
Posted on: 2010/12/17 18:23
Ditto on mine. The aftermarket "power coupler" rubber boot fit with some trimming and heat. |
Posted on: 2010/12/17 18:46
I won't go anywhere near one of those. The last two I saw were both split. Of course people put the seam down for aesthetics, and then when it goes it fills their engine with dirt for a few years before they notice.
Posted on: 2010/12/17 21:45
Aboatguy | Re: Who has used BBK Throttle bodies | ||
A BBK 58MM has been on my 355 for 5 or 6 years or so with no TB related problems
Mike |
Posted on: 2010/12/20 1:34
