256 user(s) are online (124 user(s) are browsing Forums)
Jharms C4 console lid latch spring replacement
2 Posts
Hi,
I need a description or picture of where the flat springs go to keep the latch closed. I removed the console pad and found the springs lying loose.
Can you help?
Thanks,
Jon
Posted on: 2010/10/9 20:44
Mekanic Re: C4 console lid latch spring replacement
Tampa Bay Florida
827 Posts
go from the bottom of the lid, couple screws behind the release button, spring is plastic and U shaped
Posted on: 2010/10/9 20:52
~Rich
Polo LT4
Jharms Re: C4 console lid latch spring replacement
2 Posts
Thank you - now I know I need a new one. Spring is broken into two pieces. Any idea how to obtain?
Cheers,
Jon
Posted on: 2010/10/9 21:55
BillH Re: C4 console lid latch spring replacement
Cheers,
Jon
CorvetteCentral p/n 234312, $6.95
Posted on: 2010/10/10 0:21
flyboy Re: C4 console lid latch spring replacement
I don't quite remember how, but I rigged up a cheap hardware store coil spring on mine. It wasn't too difficult and works fine.
Posted on: 2010/10/10 1:55
CentralCoaster Re: C4 console lid latch spring replacement
There's only two ways to install it, one works, one doesn't. :P
These corvette guys love leaf springs. Wonder why they didn't use leaf springs for the valves also.
Posted on: 2010/10/10 2:36
Tampa Bay Florida
827 Posts
Posted on: 2010/10/10 12:23
~Rich
Polo LT4
