TommyT-Bone | ( chucks ?) AC/Primary Fan | ||
I have a 94 base coupe with electronic climate control,with the ac off the primary fan and ac compressor still run?Any help with this would be great.
Posted on: 2010/9/6 1:20
bogus | Re: ( chucks ?) AC/Primary Fan | ||
The compressor should not run in this condition...
I would wonder if there is a problem in the climate control head or programmer. I will have to check my helm manual and see what I can regarding troubleshooting this bug. |
Posted on: 2010/9/6 1:25
chuck | Re: ( chucks ?) AC/Primary Fan | ||
Thanks for the reply,I don't have good manual to reference so any help from you guys would be great.
Posted on: 2010/9/6 1:36
I will confirm this today... I got wrapped up in rebuilding my wifes laptop yesterday... never made it out to the garage!!!
Posted on: 2010/9/7 16:53
CentralCoaster | Re: ( chucks ?) AC/Primary Fan | ||
Only on defrost or a/c.
Posted on: 2010/9/8 0:59
Ac control is turned off,and compressor and fan still running.
Posted on: 2010/9/8 20:30
I am leaning towards a failed relay.
I don't have the 1994 book, but I suspect the system is pretty much the same from 1992 to 1996. Depending on auto or manual transmission, there are 1 (a/t) or 2 (man) relays on the left front inner fender. I would start there. |
Posted on: 2010/9/9 0:49
tjpreul | Re: ( chucks ?) AC/Primary Fan | ||
This is where I would start too. A shorted a/c circuit will give you a code 68, but no SES light ('92 FSM). |
Posted on: 2010/9/9 1:23
Just wanted everbody to know this was a bad ac programmer.
Thanks for all the help. |
Posted on: 2010/9/25 1:12
TommyT-Bone | Re: ( chucks ?) AC/Primary Fan | ||
Thanks for the follow up. It's always nice to know it's repaired.
Posted on: 2010/9/25 2:08
