282 user(s) are online (130 user(s) are browsing Forums)
Driver Information Center.
BillH LeMans 24
Corvettes - P1 & 2 in GT2 right now. 4:00p.m. West coast.
A C6R is in P2 in GT1, Saleen in P1
Posted on: 2010/6/12 23:08
bogus Re: LeMans 24
20861 Posts
Watching right now!
Posted on: 2010/6/12 23:17
SpectatorRacing Re: LeMans 24
Happy to have the overnight coverage, but now I remember why they didn't have it last year...
The more I see McNish drive the more I like him.
Isn't there some soccer match on this weekend, too?
Posted on: 2010/6/12 23:34
BillH Re: LeMans 24
Me 2.
Just noticed another C6R,
A C6R is in P2 in GT1, Saleen in P1, C6R in P4
Posted on: 2010/6/12 23:35
bogus Re: LeMans 24
20861 Posts
Soccer is over for today. The late game was at 11:30AM PDT.
England v. US tied @ 1.
We met McNish at Sebring a couple years ago. He is one helluva nice guy.
Posted on: 2010/6/13 0:13
BillH Re: LeMans 24
Did you know that some of the corner workers are SCCA- San Francisco Region corner workers?
Posted on: 2010/6/13 0:19
bogus Re: LeMans 24
20861 Posts
no, I didn't know that. Good for them! Way cool!
Posted on: 2010/6/13 0:22
BillH Re: LeMans 24
Yea, San Francisco in my region of record, I've been on the corners with some of these guys.
And the SCCA Reno Region RE (Regional Exec.) and his wife have their FIA credentials, headed to Spain this month, I think to work the F1 race.
Posted on: 2010/6/13 0:35
Steve40th Re: LeMans 24
1114 Posts
Posted on: 2010/6/13 2:46
Ko'u ohana aia ku'a ikaika
1114 Posts
Awesome trick to watch the race. Using vlc player, open player, go to
media > open network... > protocol = HTTP > address = 95.211.123.74:51004 > play
Lags a little.
Posted on: 2010/6/13 3:50
BillH Re: LeMans 24
I'm crashing early so I can get up early for the finsh.
Watching one is way less tiring than being in one. But, I watched all of it so far, getting burnt out.
Posted on: 2010/6/13 4:18
bogus Re: LeMans 24
20861 Posts
sleep tight!
I won't be up early... I am taping the rest.
Posted on: 2010/6/13 4:24
bogus Re: LeMans 24
20861 Posts
#63 Corvette, Johnny O, Jan and Antonio, is out!
Engine failure. Doug Fehan indicated the crankcase sensor showed a major engine failure.
Just prior to that, the lead Peugeot blew up in a big way.
Audi leads P1, Corvette #64 still leads GT2.
Posted on: 2010/6/13 5:09
bogus Re: LeMans 24
20861 Posts
#64 Corvette was wrecked by an overzealous Anthony Davidson in a Peugeot.
The rear was pretty bashed in, but they are work on it. The damage is in the rear section. The body work is toast, the rear wing, which houses the oil cooler, has been crushed. The real problem is the hole in the dry sump oil tank.
Posted on: 2010/6/13 6:36
Fluff Re: LeMans 24
Winchester UK & Alicante ES
247 Posts
They did well and got the #64 out again.
Then a few laps later it retired with engine failure!
All bad luck this year!
Posted on: 2010/6/13 7:49
93 LT1 Coupe.
BillH Re: LeMans 24
Well, that sucks. But that's racin'.
All the Peugeots are out, so......
Being overzealous when you're running at the front isn't real smart, IMO.
I got knocked off the track in a 25 hour race by the leader one time, he had a full lap on second place at the time. Put his win in jeopardy by doing so.
The engine failures seem unusual for Team Corvette.
Hope they kick ass next year.
jpg  mcqueen2.jpg (0.00 KB)
Posted on: 2010/6/13 12:40
1114 Posts
Arent the GT2 engines identical engines with the exception of a shorter stroke? I wonder if they are revving them higher than the 7.0 litre engine and this is beyond the capability, especially on continuous runs like Mulsanne.
Posted on: 2010/6/13 14:07
BillH Re: LeMans 24
2009 Specs:
2009 Corvette Engine Specifications
2009 Corvette ZR1
2009 GT2 Corvette C6.R
Displacement (L / ci):
6.2 / 376
6.0 / 366
Horsepower:
638 @ 6500 rpm
470 @ 4800 rpm
Torque (lb-ft):
604 @ 3800 rpm
535 @ 4500 rpm
Bore diameter (mm / in):
103.25 / 4.06
106.2 / 4.180
Crankshaft stroke (mm / in):
92 / 3.62
84.33 / 3.32
Deck height (mm / in):
235 / 9.24
235 / 9.24
"V" angle (deg):
90
90
Cylinder bore spacing
(mm / ci):
111.7 / 4.40
111.7 / 4.40
Valvetrain:
pushrod with overhead valves, titanium inlet
pushrod with overhead valves, titanium inlet and exhaust
Valves per cylinder:
2
2
Camshaft drive:
chain
chain
Cylinder case material:
aluminum
aluminum
Cylinder liners:
dry iron
none
Cylinder head material:
aluminum
aluminum, CNC ported
Lubrication system:
dry sump
dry sump
Fuel system:
sequential EFI
sequential EFI
Throttle system:
supercharged w/intercooler, throttle body
individual runner
Fuel:
premium unleaded gasoline required
E85R ethanol
2010 may be different. It's strange that the HP on the GT2 is rated at 4,800
Posted on: 2010/6/13 14:18
BillH Re: LeMans 24
Where the C6.R and ZR1 differ significantly are in situations where GT rules actually prohibit the use of the more sophisticated ZR1 components. For example, the ZR1 is equipped with carbon-composite brake rotors, while GT regulations require ferrous (steel) brake discs. And, where the ZR1 utilizes a 6.2-liter supercharged\ V-8, the C6.R uses a naturally aspirated, production-based 5.5-liter small-block V-8.
The Corvette C6.Rs' engines are developed, built and maintained by GM. Designated LS5.5R, the naturally aspirated powerplant is based on the Corvette Z06's 7.0-liter LS7 engine (which in turn was developed with the 7.0-liter race engine used in the C6.R GT1 cars), and is built with a production cast-aluminum cylinder block.
Pending GT2 class regulations specify a maximum displacement of 5.5 liters. The reduction in displacement to meet this requirement was achieved by shortening the crankshaft stroke and reducing the cylinder bore diameter. In accordance with the regulations, the race engines have two 28.8mm diameter intake air restrictors. The LS5.5R engines are equipped with dry-sump oiling systems, CNC-ported aluminum cylinder heads with titanium intake and exhaust valves, and sequential electronic port fuel injection. The race engines use E85R ethanol racing fuel in the ALMS and E10 fuel in Le Mans.
Posted on: 2010/6/13 14:40
bogus Re: LeMans 24
20861 Posts
There is enough difference between the GT1 and GT2 engines that I am not surprised they had teething problems.
The wreck with Davidson damaged the oil tank. They had to replace it. The feeling was that enough oil existed in the lines to keep the engine healthy considering the short, low speed, distance travelled. Apparently not.
Posted on: 2010/6/13 17:02
BrianCunningham Re: LeMans 24
Katech used to build their racing engines
GM will have some teething issues.
Better for GM in the long term since the lessons learned will be passed on.
Posted on: 2010/6/13 19:07
Posted on: 2010/6/13 19:18
Lags a little.
cool
any other Linux hacks I should know about?
Posted on: 2010/6/13 19:26
bogus Re: LeMans 24
20861 Posts
The lessons learned were already passed on.
Posted on: 2010/6/13 20:17
1114 Posts
On the thread I linked with Video, some guy on there was chatting and told people to do it to get audio. On WiFi it wasnt very good. But, its there. It opens up some doors on things now, knowing you can do that.
I love VLC, it plays everything.
Posted on: 2010/6/13 20:19
I think after today they learned a few more things.
Posted on: 2010/6/13 20:20
