Browsing this Thread:
2 Anonymous Users
Fluff | Rear lights on a C4 | ||
Can anyone tell me about the standard US spec for the rear lights on a 93 C4. Does each of the 4 red lights have a combination of rear/stop/turn bulbs as standard?
Mines been converted to euro spec and I want to do some changes, but I'm not sure what wiring/configuration was originally there. |
Posted on: 2010/6/3 22:46
93 LT1 Coupe. |
bogus | Re: Rear lights on a C4 | ||
originally, the C4 rear lights are both red, both turn, both marker and both brake.
Easy. Moving to C4 Tech. |
Posted on: 2010/6/4 5:01
vis_croceus | Re: Rear lights on a C4 | ||
Each lamp has one dual-filament bulb, type 2057. |
Posted on: 2010/6/5 4:44
94 vert ![]() |
Fluff | Re: Rear lights on a C4 | ||
Thanks Andy & vis,
That sounds good. Depending on what was done during the euro conversion I should be able to do a mod to accept 4 amber & red combination units. Where do I find the flasher unit/relay on a 93? |
Posted on: 2010/6/6 10:12
93 LT1 Coupe. |
The flasher is under the driver side knee bolster, IIRC... just about every relay is under the right side knee bolster.
Posted on: 2010/6/6 22:28
Thanks Andy.
Posted on: 2010/6/7 11:22
93 LT1 Coupe. |
