220 user(s) are online (109 user(s) are browsing Forums)
Print in friendly format Send this term to a friend  Ruby
Refers to 1993 Anniversary Editions.
These are the actual cars honored as anniversary cars. They have RPO Z25 to prove it....
Weavsvet Liquid Teflon
446 Posts
Where can I get it?
I Googled it but can't see to find the right thing. Is it called anything else? Thanks
Posted on: 2010/5/29 18:16
Weavsvet Re: Liquid Teflon
446 Posts
Never mind, I found it, it's also called Loctite 545
Posted on: 2010/5/29 18:28
Aboatguy Re: Liquid Teflon
My Avatar was redistributed!
498 Posts
I've been using GM 1#12346004
Pipe Sealant with PTFE with good results ..a little seems to go a long way...I've been using the same tube for 3 or 4 years ...
Posted on: 2010/5/29 19:40
Matatk Re: Liquid Teflon
22814 Posts
I bought the ARP thread sealant.
Posted on: 2010/5/29 22:03
446 Posts
I got some of that also, is it just as good?
Posted on: 2010/5/29 22:28
22814 Posts
What exactly are you looking for/using it for? I looked up loctite 545 and that's super expensive stuff for high pressure hydraulic systems. Did you mean loctite 565?
https://jdparts.deere.com/partsmkt/doc ... hreadSealants_Loctite.htm
The ARP thread sealant I have is for things like water pump bolts, etc - it's high temp and high pressure.
Posted on: 2010/5/30 0:22
446 Posts
It was 565, sorry. I mainly wanted something good to seal the intake rocker studs with. I have to remove the 3/8 studs from the AFR's and install my 7/16 studs. 565 is probably over kill but that's kind of my nature.
Posted on: 2010/5/30 5:21
22814 Posts
I've never compared them side by side but they are probably the same thing.
Posted on: 2010/5/30 11:17
mseven Re: Liquid Teflon
Motor City Madhouse
247 Posts
IMO, the teflon liquids/pastes are all pretty similar and pretty much give the same results. I have a few types here and see no difference. I have been using the using permatex version, locktite, ARP, and vibra tite (parker/earl), and I end up using the first one in reach.
Posted on: 2010/5/30 13:46
jaa1992 Re: Liquid Teflon
Stone Mtn, GA (near Atlanta)
187 Posts
I use the permatex.
Tried the ARP one time and it didn't seal very well.
I haven't had a problem with the permatex
Posted on: 2010/5/31 2:16
