Weavsvet | Liquid Teflon | ||
Where can I get it?
I Googled it but can't see to find the right thing. Is it called anything else? Thanks |
Posted on: 2010/5/29 18:16
1996 Corvette Coupe,AFR 195 street Eliminators,Edelbrock LT4 Air Gap intake manifold,9.5" 2800 stall,TPIS LT headers,Bullet 226/230.565.565/111 lsa cam,1.7 Scorpion rr's,EWP, X Pipe, Stock Exhaust,Elec.Cutouts,Dana 44/3.45, Tune by Wester's Garage |
Weavsvet | Re: Liquid Teflon | ||
Never mind, I found it, it's also called Loctite 545
Posted on: 2010/5/29 18:28
Aboatguy | Re: Liquid Teflon | ||
I've been using GM 1#12346004
Pipe Sealant with PTFE with good results ..a little seems to go a long way...I've been using the same tube for 3 or 4 years ... ![]() |
Posted on: 2010/5/29 19:40
Matatk | Re: Liquid Teflon | ||
I bought the ARP thread sealant.
Posted on: 2010/5/29 22:03
I got some of that also, is it just as good? |
Posted on: 2010/5/29 22:28
What exactly are you looking for/using it for? I looked up loctite 545 and that's super expensive stuff for high pressure hydraulic systems. Did you mean loctite 565?
https://jdparts.deere.com/partsmkt/doc ... hreadSealants_Loctite.htm The ARP thread sealant I have is for things like water pump bolts, etc - it's high temp and high pressure. Matthew |
Posted on: 2010/5/30 0:22
It was 565, sorry. I mainly wanted something good to seal the intake rocker studs with. I have to remove the 3/8 studs from the AFR's and install my 7/16 studs. 565 is probably over kill but that's kind of my nature. |
Posted on: 2010/5/30 5:21
I've never compared them side by side but they are probably the same thing.
Matthew |
Posted on: 2010/5/30 11:17
mseven | Re: Liquid Teflon | ||
IMO, the teflon liquids/pastes are all pretty similar and pretty much give the same results. I have a few types here and see no difference. I have been using the using permatex version, locktite, ARP, and vibra tite (parker/earl), and I end up using the first one in reach.
Posted on: 2010/5/30 13:46
jaa1992 | Re: Liquid Teflon | ||
I use the permatex.
Tried the ARP one time and it didn't seal very well. I haven't had a problem with the permatex |
Posted on: 2010/5/31 2:16
