249 user(s) are online (130 user(s) are browsing Forums)
pr0zac would there be a benefit for me running E85?
i have a higher compression engine and it is available local.
Posted on: 2010/2/27 19:55
Matatk Re: would there be a benefit for me running E85?
22815 Posts
Have you changed all of your rubber lines and seals to be E85 compliant? (Most cars from the 90s and newer are already ethanol ready) Do you have a new computer to adjust for it? That's the biggest thing - the sensors and computer to know how to adjust for the difference in fuel. The older cars can be brought into compliance with the requirements, but probably not worth it. So, in short, no.
The benefit on newer cars with high HP builds is that there is less detonation and they can advance the timing...a lot.
Posted on: 2010/2/27 22:41
pr0zac Re: would there be a benefit for me running E85?
my car is a 96. i have a few pcm's for it and the ability to tune them. my static compression ratio is 12.3:1. if its safer to run that then i have no issues in making it work.
Posted on: 2010/2/27 22:51
22815 Posts
I don't want to portray myself to know more about E85 than I do. I wish I could help you more in depth, but there are some experts out there. Perhaps you can find some more info on a web search.
Posted on: 2010/2/27 23:03
Ultraman Re: would there be a benefit for me running E85?
14804 Posts
Take a look at www.flexfuelus.com they say that they can get you going with the stuff they sell. I always heard it took a stainless tank and lines to handle the corrosive nature of the product. Leno likes it and talks about it on his garage site.
I am running it in my Tahoe which is made for it and went from an overall 14.5 fuel avg. to about 12.5 avg. It cost me 2.14 vrs. 2.67 for E10 downtown.
Posted on: 2010/2/27 23:47
dan0617 Re: would there be a benefit for me running E85?
I've wondered myself if a benefit could be had in my engine (high compression also), but it isn't readily available around here so I never pursued it.
Posted on: 2010/2/28 0:54
BrianCunningham Re: would there be a benefit for me running E85?
since it's a '96 with the crank sensor, you might be able to get it to run on the newer FlexFuel computers.
though you'd have to piggy back in the old ECU to keep the dash working.
Posted on: 2010/3/1 16:14
there is no way to tune one of my computers to run the e85?
Posted on: 2010/3/1 16:35
you can get it to run E85
If you want the option of running EITHER gas of E85 the later ones will help.
check this out
http://www.ls1tech.com/forums/lt1-lt4 ... -numbers-e85-520rwhp.html
Posted on: 2010/3/1 16:48
