211 user(s) are online (107 user(s) are browsing Forums)
astock165 Banski MotorSports now has the Hardbar pintop shock mounts in a C4 specific kit
Manchester NH
199 Posts
We're excited to announce that we now have the great pin top shock mount from our friends @ Hardbar USA. When we first saw this product we knew it would be a big hit and also knew it would go so well with our C4 rear suspension kit.
The C4 specific kit comes with the same pin top shock mount as used on the C5 & C6 and also includes two new stainless steel "eyeball" plates to replace the stock ones on the rear of your C4. These eyeball plates make the kit an entirely bolt in installation with no modifications necessary.
Swing by our website to check out what we have and browse our online store.
Posted on: 2010/2/26 3:32
Banski MotorSports LLC
Manchester NH
tom@banskimotorsports.com
www.banskimotorsports.com
Matatk Re: Banski MotorSports now has the Hardbar pintop shock mounts in a C4 specific kit
22815 Posts
I read the page, but I don't really recall the difference between this and the stock setup (it was two years ago I changed shocks). What's the overall benefit for the street, or is it more for track use?
Glad to see you guys still support the C4 so much
Posted on: 2010/2/26 3:40
astock165 Re: Banski MotorSports now has the Hardbar pintop shock mounts in a C4 specific kit
Manchester NH
199 Posts
The benefit is that it allows the shock to pivot with almost no side loads on the pin top of the shock. The stock rubber or aftermarket urethane bushings need to be compressed for the shock to pivot, which puts a bending load on the pin top. This kit allows it the pin top to pivot almost effortlessly.
The benefits are for both street & track as any time you reduce the forces on the mounting portions of your suspension components the better those components will work to maximize your grip.
With corrosion resistant stainless steel and Delrin this kit needs no grease and will be quiet on the street and track.
Posted on: 2010/2/26 3:47
Manchester NH
Aboatguy Re: Banski MotorSports now has the Hardbar pintop shock mounts in a C4 specific kit
My Avatar was redistributed!
498 Posts
Does this work with FX3 shocks???
Is this just a replacement for the top shock mount?
Posted on: 2010/2/27 0:22
Manchester NH
199 Posts
That's an interesting question as I have yet to see them on a car with the stock style FX3 shocks.
I will look into it and post what I find.
Would you be able to email me or post some pics of the tops of your FX3 shocks? Both front & rear?
Posted on: 2010/2/27 22:30
Manchester NH
498 Posts
I have a pair of rears on the shelf...would pics of fronts in the car be OK?
Posted on: 2010/2/27 23:22
498 Posts
Fronts
[IMG]http://i14.photobucket.com/albums/a342/aboatguy/Car/shocks/DSC02186.jpg[/IMG]
[IMG]http://i14.photobucket.com/albums/a342/aboatguy/Car/shocks/DSC02187.jpg[/IMG]
[IMG]http://i14.photobucket.com/albums/a342/aboatguy/Car/shocks/DSC02188.jpg[/IMG]
Posted on: 2010/2/27 23:37
498 Posts
REAR
[IMG]http://i14.photobucket.com/albums/a342/aboatguy/Car/shocks/DSC02189.jpg[/IMG]
[IMG]http://i14.photobucket.com/albums/a342/aboatguy/Car/shocks/DSC02190.jpg[/IMG]
[IMG]http://i14.photobucket.com/albums/a342/aboatguy/Car/shocks/DSC02191.jpg[/IMG]
Posted on: 2010/2/27 23:49
498 Posts
I believe the answer is going to be a big old neqative...or NO!
My FX3 shocks are 12 MM at the location shown in the following picture:
[IMG]http://i14.photobucket.com/albums/a342/aboatguy/Car/shocks/DSC02192.jpg[/IMG]
Posted on: 2010/2/28 0:06
Manchester NH
199 Posts
From the pics you've posted the kit would mount properly where it needs to as the FX3 sensors are above the stock rubber bushings on both front & rear.
If the rod on your shock is 12 mm then you're correct in that the kit will not fit as it is specifically for a 10 mm shock rod. However, that doesn't necessarily mean it could not be modified to work for your application.
If you'd like to pursue this, contact me via email and we can discuss it further.
Posted on: 2010/2/28 17:19
Manchester NH
498 Posts
You have a PM.....
Posted on: 2010/2/28 20:21
Manchester NH
199 Posts
In a discussion I've been having offline with Aboatguy I went back to find these videos that Hardbar made when they first released this product last summer. They'll clearly show some of the benefits of this product.
This video shows how a shock with a stock C6 rubber bushing on top and bottom reacts.
http://s67.photobucket.com/albums/h28 ... ew¤t=rubbertest.flv
This video shows how adding only the top half of the mount cuts down on the "jumping" the shock does.
http://s67.photobucket.com/albums/h28 ... ent=HardbarDelrintest.flv
Finally here is a video showing how easily the shock will pivot with this mount.
http://s67.photobucket.com/albums/h28 ... view¤t=P7080015.flv
Posted on: 2010/3/1 18:36
Manchester NH
498 Posts
You have an order!
Posted on: 2010/3/1 23:57
CentralCoaster Re: Banski MotorSports now has the Hardbar pintop shock mounts in a C4 specific kit
What is your opinion on the eyelet design for the 84-87 rear shock mounts?
Posted on: 2010/3/2 0:29
Manchester NH
199 Posts
I think it's a shortcoming just like any rubber or poly bushing as compared to a spherical type of bearing, and it's not limited to the rears of 84s to 87s. A similar eyelet design is on the bottom front of all C4s (IIRC) and the bottom of the rears on the 88s to 96s as well.
Unfortunately it's not an easy thing to address in an existing shock designed for that type of bushing. It's funny that you bring this up because I fell into a nice deal on some slightly used Bilstiens for my 93 and when I got them I wanted to retrofit the bottoms of all four with a spherical bearing. As I measured them up and was going through the design process I actually found that it was more trouble than I thought is was worth and have put the project aside.
My plan is to put them on my car with the Bilstien bushings in the bottom and the Delrin/SST pin top mounts.
Posted on: 2010/3/2 1:30
Manchester NH
I see your point on the eyelets in back, but in front there is only one axis of rotation for the control arm, so if the shock is perpendicular to the LCA pivot axis, eyelets would work top and bottom. I don't see where a spherical setup would help the geometry.
As for the materials... it seems like something like this could work. You could machine grooves in the eyelet to hold the snap rings in place or fabricate some other means of sandwiching or clamping it in there.
http://www.mcmaster.com/#rod-ends/=61mco6
Posted on: 2010/3/2 17:37
Manchester NH
199 Posts
CentralCoaster wrote: I see your point on the eyelets in back, but in front there is only one axis of rotation for the control arm, so if the shock is perpendicular to the LCA pivot axis, eyelets would work top and bottom. I don't see where a spherical setup would help the geometry.
Exactly right and all I really wanted to do was to be able to account for the fact that the shock will probably never be perfectly perpendicular to that axis in the real world. If I can easily account for some off axis deflection I like to.
CentralCoaster wrote:As for the materials... it seems like something like this could work. You could machine grooves in the eyelet to hold the snap rings in place or fabricate some other means of sandwiching or clamping it in there.
That's what I started working towards. I just found the eyelets on the front Bilstiens I have were sized such that the spherical bearing I ended up using was smaller than I wanted and the T-bar on the bottom would have been much smaller than I would have been comfortable with. The front shocks had a tapered cross section to its eyelet, complicating the bearing holders.
Below is what I started to develop but just didn't think it was worth the effort for a set of shocks I really only plan on using for a season or two until I can upgrade to Penskes with the spherical bearing bottom mount anyway.
Posted on: 2010/3/3 1:35
Manchester NH
sidney004 Re: Banski MotorSports now has the Hardbar pintop shock mounts in a C4 specific kit
Castro Valley, CA
15 Posts
Tom:
Is it compatible with the FX3 shocks?
Posted on: 2010/3/4 7:06
Manchester NH
199 Posts
sidney004 wrote:
Tom:
It's compatible in that the stock rubber bushings go in the same place on either non-adjustable or FX3 shocks. Many thanks to Aboatguy for posting the pics above of his FX3s.
The kit is currently designed specifically for a 10 mm shock shaft but should be relatively easy to modify for a slightly bigger shaft. I am actually working on getting that set up now and plan on modifying a kit for FX3s in the next couple of days.
When I get that finished I'll make sure to post updates to let everyone know.
Posted on: 2010/3/4 12:49
Manchester NH
498 Posts
Here's a little more info...the inside diameter of the metal sleeve inside the bushing is 12.7mm or .5 inches
[IMG]http://i14.photobucket.com/albums/a342/aboatguy/Car/shocks/DSC02195.jpg[/IMG]
and approximately 44.15 mm long
[IMG]http://i14.photobucket.com/albums/a342/aboatguy/Car/shocks/DSC02196.jpg[/IMG]
Posted on: 2010/3/5 0:52
Manchester NH
199 Posts
We just completed the first modification to fit an FX3 shock. Once we had a shock in hand it was a pretty simple mod so we will be offering an FX3 specific kit in addition to the kits for C4s with 10 mm shock rods.
Below is a pic of a rear FX3 equipped shock with the pin top mount in place.
Here is a pic of how the FX3 sensor fits nicely into a modified Stainless Steel cap:
Posted on: 2010/3/17 1:53
Manchester NH
498 Posts
Looks sweet...I bet there will be some installed pics soon...
Posted on: 2010/3/18 0:24
498 Posts
They're here!!!They're here!!!
[IMG]http://i14.photobucket.com/albums/a342/aboatguy/Car/shocks/DSC02198.jpg[/IMG]
Posted on: 2010/3/22 21:41
