lindenbob | Bosch 3 Injector installed Pic + | ||
Posted on: 2009/11/21 7:45
Matatk | Re: Bosch 3 Injector installed Pic + | ||
Excellent! Glad you got it buttoned up without a problem.
Matthew |
Posted on: 2009/11/21 12:55
1Fast04Vert | Re: Bosch 3 Injector installed Pic + | ||
It would be nice if all jobs were as easy as LT1/4 injectors. The manifolds look great.
Posted on: 2009/11/21 13:42
lindenbob | Re: Bosch 3 Injector installed Pic + | ||
Thanks. Yes injectors are a snap. Now the exhaust manifolds removal. That is one of them jobs half way thru you ask yourself why am I doing this? |
Posted on: 2009/11/21 22:43
383tpimachine | Re: Bosch 3 Injector installed Pic + | ||
L98 injector swap is a pain. glad I changed to a HSR intake can you notice a change in the driving? |
Posted on: 2009/11/21 23:16
pianoguy | Re: Bosch 3 Injector installed Pic + | ||
Looks great!!
Posted on: 2009/11/21 23:31
corvetteronw | Re: Bosch 3 Injector installed Pic + | ||
I was wondering about doing that to my 91's exhaust manifold until I can afford to buy headers. What problems do you run into when not running the heat shields? Do you have extra insulation on the plug wires that are near these manifolds?
Posted on: 2009/11/24 4:43
A VETERAN IS SOMEONE WHO AT ONE POINT WROTE A BLANK CHECK MADE PAYABLE TO THE UNITED STATES OF AMERICA FOR AN AMOUNT OF UP TO AND INCLUDING THEIR LIFE. |
For the time, effort and funds to coat the manifolds I wouldn't do it if you are planning to put headers on in the near future. As far as heat, this coating is rated to 1300 F and are coated inside and out which drops the manifold temp from 400-300 degress cooler than uncoated manifolds. The heat shields only cover the sides and warm air rises. So they don't do much for protecting wires to begin with. I will not know if it has any adverse effects until I start doing longer runs in the spring. I have standard 8.5 mm silicone wires and don't figure there to be any problems. You can almost put your hand on the manifolds while it is running. The ceramic coating channels most of the heat right out the exhaust. [img align=right width=300] ![]() |
Posted on: 2009/11/24 10:03
BrianCunningham | Re: Bosch 3 Injector installed Pic + | ||
My MSD wires wouldn't fit in the stock looms, so I took the sheetmetal brackets off.
I got sick of getting cut by them. |
Posted on: 2009/11/24 14:16
Posted on: 2009/11/29 2:20
