258 user(s) are online (127 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
TommyT-Bone ( chucks ?) AC/Primary Fan
33837 Posts
I have a 94 base coupe with electronic climate control,with the ac off the primary fan and ac compressor still run?Any help with this would be great.
Posted on: 2010/9/6 1:20
bogus Re: ( chucks ?) AC/Primary Fan
20861 Posts
The compressor should not run in this condition...
I would wonder if there is a problem in the climate control head or programmer.
I will have to check my helm manual and see what I can regarding troubleshooting this bug.
Posted on: 2010/9/6 1:25
chuck Re: ( chucks ?) AC/Primary Fan
3 Posts
Thanks for the reply,I don't have good manual to reference so any help from you guys would be great.
Posted on: 2010/9/6 1:36
20861 Posts
I will confirm this today... I got wrapped up in rebuilding my wifes laptop yesterday... never made it out to the garage!!!
Posted on: 2010/9/7 16:53
CentralCoaster Re: ( chucks ?) AC/Primary Fan
Only on defrost or a/c.
Posted on: 2010/9/8 0:59
3 Posts
Ac control is turned off,and compressor and fan still running.
Posted on: 2010/9/8 20:30
20861 Posts
I am leaning towards a failed relay.
I don't have the 1994 book, but I suspect the system is pretty much the same from 1992 to 1996.
Depending on auto or manual transmission, there are 1 (a/t) or 2 (man) relays on the left front inner fender.
I would start there.
Posted on: 2010/9/9 0:49
tjpreul Re: ( chucks ?) AC/Primary Fan
This is where I would start too. A shorted a/c circuit will give you a code 68, but no SES light ('92 FSM).
Posted on: 2010/9/9 1:23
3 Posts
Just wanted everbody to know this was a bad ac programmer.
Thanks for all the help.
Posted on: 2010/9/25 1:12
TommyT-Bone Re: ( chucks ?) AC/Primary Fan
33837 Posts
Thanks for the follow up. It's always nice to know it's repaired.
Posted on: 2010/9/25 2:08
